Sendt corretion signals from base connected to local wifi, over internet (fiber) to www.rtk2go.com, this is broadcasting and sending to my portale LTE 4g router with wifi LAN and rover connected set up to receive correction data.
I can see correction data coming through as shown below. Really cool
Anybody els got this up and running?
Btw! Both units is inside the house.
Was thinking of making a video of this, anybody know of a tool that easilycan scramble sensitiv info on screen?
This step by step guide explain how to set up one Reach unit as base providing a second Reach unit as rover with free open ntrip correction data from one point to another over internet. This way is not secure and your server will be open for others to see.
This guide assume basic knownledge about Reach and how to navigate and configurate it.
If not, start here
For this guide i used:
2 x Reach units with stock antenna and beta firmware 2.1.6
1 x LTE portable router with sim card (see pictures above) Spec
1 x Local wifi ( i used my own wifi at home with internet connection)
1 x computer to work from (phone/tablet is possible but pc is much easier and faster to work with)
and access to www.rtk2go.com webpage
Note. Both Reach units is placed indoor, that explains the poor signal
1.
Set up wifi so that both Reach units can connect to it. I have one wifi called dd-wrt and the other called RTK.
For this purpose dd-wrt acts as my home wifi connected to internet via local fiber and RTK is my portable wifi and connected to internet via LTE (router with 4g sim card in it). It should be possible to use phone as hotspot as well
I also saved both wifi points to both Reach units. From Reach menu its easy to select which unit should connect to wifi.
Now, connect one Reach unit to each of your wifi networks.
2
Start with the base and open base mode window. See picture below. Info used here you can find at rtk2go webpage, password might change but for now it is BETATEST. Montpoint to could choose your self.
3
Next, config the Reach as rover.
Username is the same as mountpoint. When you select mountpoint a drop down menu is visible and if the base is configurated correct, it will show up here. If not, you dont have set the base right and correction data is not beeing sent to www.rtk2go.com
Once all info is typed in and setting applied,you will se correction data showing up at the bottom of this menu.
Awesome right up! Exactly what I need! Do I have to use that tp-link router or can I use a regular router on repeater mode (since we have 4g lte hotspots)?
Thank you so much , i was looking for something like that for my work, I’ll try it soon.
I don’t have a LTE router, do you think a share connection from cell phone work?
Other then mount point is not filled, i know there could be some hassel to add credentials in the right order.
I hade some issues if adress was filled in before the mountpoint or the other way…
But you should get a dropdown menu when www.rtk2go.com is filled first, and then be able to select your point.
Tried adding only address and port but still no dropdown (on the module that was configured as base). Am I supposed to enter “BETATEST” as password? Can’t seem to save it without a username though.
