Reach to Leica GPS1200 results comparison
I finally got around to comparing Reach to our Leica GPS1200 survey grade GPS. This little article tries to explain my methodology and solutions when trying to underake a static point survey, such as placing of ground control points for UAV surveys.
The site chosen for the comparison is an active construction site near to Durban, South Africa. Points were surveyed by our office 3 months ago via a Leica GPS1200. The points have been semi permanently marked with road marking paint on tar, plastic bags arranged in “X” formation and other ways, making all points visible from the air for photogrammetric uses. The points were initially measured in RTK and then confirmed with a local NTRIP VRS server. The survey is based on the VRS coordinate system, Hartebeesthoek94 / Lo31 (EPSG:2054).
I wanted to test the Reach in 2 ways. The first being via RTK ways and then by post processing. A total of 3 Reach devices were used. It was decided to not use the Reach with an attached RFD900 radio. Previous tests have shown that the radio range, even at maximum power output, is not really useful for terestrial work. We suspect that the polarization of the antennas is best suited for ground to air communications. It as then decided to send RTCM data via a TCP server, connected to an ADSL line(via a WIFI router)
The first Reach was installed at our office, 3km away from the site. This Reach, “BASE1” was to act as a reference base. The Reach was connected to the office WIFI and assigned a static IP. The antenna was installed on the roof of the office with a 300mm x300mm metal plate acting as a ground plane. The Reach was connected to our VRS and a coordinate was determined within 20 seconds. The point was averaged for over 30 seconds. This point occupation would form the basis of our control system making it easier to compare to the true system.
“BASE1” now had a coordinate, and was set to “Base” mode. The coordinate entered in the respective fields, the output set to “TCPServer”, GPS and GLONASS data was sent at 1HZ. Before leaving the office, we tested that the data stream was accessible from outside of our local network via the Android app “Lefebure NTRIP Client”
On the site, “BASE2” was installed. This consisted of an antenna being installed on a 300mm x300mm metal plate acting as a ground plane, in an open area, elevated on a wooden fence post. The Reach was connected to a portable WIFI router, in turn connected to a public 3G service. The portable WIFI router was used as an access point to use Reachview as well as the internet. A Androind cellphone was also connected to the mobile WIFI network and Reachview accessed via Chrome browser. “BASE2” was initialized with the default Reach settings and configured to use “BASE1” via TCP client. After a 15 seconds, a solution was derived and stored. Reach was then placed in the default “Single” mode with GPS/GLONASS satellites being used at 1hz. The data being stored onboard.
Various points were then surveyed about the site. The 3rd Reach was setup on a 2m pole. The antenna placed on a 200mmx200mm sheet metal plate, and a plumbing bubble installed on the pole to ensure it was held vertically over every point. The point was located and then the pole/antenna positioned over the previously surveyed mark. The Reach was placed in the default RTK mode but “Static” was the operation of choice as the antenna would not be moving during the observation window. RTCM data was being received from “BASE1”, all raw observations were being stored as well as the solution. The measurement windows lasted for 60 seconds per point, at 1hz. Most points had open clear view of the sky about them, but 2 locations had high tension power lines overhead, which made for some interesting results. The starting points were measured at the end of the survey again to ensure that the base had not moved and to test the integrity of the data.
After each point was measured, the base was retrieved and the data downloaded. Rinex files were determined for “BASE2” and for each of the measurements. The solutions calculated in the field were collected and tabulated ofr each point. The TCP measured data collected from BASE1 was also tested via RTKLIB v2.4.3 b8. The exact same result was created on a PC via post processing from BASE1 to what was determined in the field.
Post processing from BASE2 yielded much better results. These were tabulated and compared to the original values from the Leica GPS. The configuration used to calculate the positions was the default RTKLIB settings, using Static modes and a single solution derived.
This is a really accurate result from such affordable and simple hardware. Using proper survey techniques and understanding what is going on with processed GPS data helps a lot in getting the best from these devices.
We have conclude that:
  • Post processing is really robust and works well to getting good results, especially regarding heighting
  • There are a few latency issues with using a TCP server. We think that in our case, having the data being streamed at 5hz from BASE1 > Router > ADSL > Internet > 3G > Mobile WIFI > Reach is a bit long winded causing data loss.
  • 1hz is perfectly fine for static observations. For post processing, good measurements come from long observation windows and not the amount of raw data used to process with.
  • Having a good ground plane helps a lot to reduce multipath as well as having obstruction free view of the sky.
  • It would be really great if coming versions of Reach could also allow for raw observations to be recorded while in “Base” mode. These could be used as a back up if the communication goes down between units as well as offering a more more robust solution possibility.
Device Setup is as follows:
BASE1
Reach running Reach image V1.1, Reachview V0.1.0
Powered via 5v USB at 2ah
Tallysman TW-4721 placed on 300mmx300mm sheet metal, unobstructed
Conected via WIFI/4mbps internet ADSL connection
Static IP TCP Server
Broadcasting RTCM data at 5hz
BASE2
Reach running Reach image V1.2, Reachview V0.1.0
Tallysman TW-2410 placed on 300mmx300mm sheet metal, unobstructed
No internet / WIFI connection
Recording raw data at 1hz
Rover
Tallysman TW-4421 placed on 200mmx200mm sheet metal on 2m plumbing pole
Mobile WIFI connection via 3G for Reachview / TCP client
I think I should further qualify that in the table, the XYZ are in meters, the coordinate system being Hartebeesthoek94 / Lo31 (EPSG:2054). These were calculated from the raw processed WGS84 coordinates in ArcGIS and the matching geoid model applied to obtain orthometric heights.
Hello Luke
Your findings are very interesting. Thank you for sharing.
I don’t have a RTK Reach kit yet but I was wondering what would you do or recommend to change in the sett up if no mobile service was available in the area.
I am interested in using Reach with 1 base and 1 rover in static mode for GCP in aerial survey. So I was wondering how to get raw data for each reach and post processing, no necessarily connecting them in the field. Is that possible?
Than you!
Hi Inti
So you do not need internet to be able to connect to the devices in the field. You can use your phones hotspot as a gateway, figure out the devices IP address, then connect on your mobile phone in the field.
The logs you want to download to your PC for processing afterwards. You can then connect them via the hotspot again or via your wifi later to retrieve the logs.
Internet is not needed for any of the reach functions with exception of the RTK options like NTRIP.
The default Reach single setup is perfectly fine for post processing work. Just choose what rate (1hz seems to be fine) and the satellite types(GPS, GLONASS, whatever).
Dont forget to end the observations when you are done!
However, I think the Emlid boys are planning a full post processing tutorial soon, in case my explanation is a bit coarse.
Hello Luke, Congratulations on this test.
Did you go on to perform other tests with greater distances, type 15 km from the base?
Yes, in Mozambique we did some control points that were about 14km from the base. While we didn’t get very good tracklogs of our flights onboard, the control actually turned out OK. We used Precise Ephemeris data to strengthen the observations and held points for about 10min.
When we came to reobserve or check out points, the variations were only a few cm.
But this was an extreme case, with the sky being completely free from any obstructions.
puedes publicar tus resultados, pienso comprar 02 GPS, pero necesito saber si se puede hacer base lineas de 50 km modo estático.
