Hello everyone,
We’ve just released the Reach Firmware 26.2 that contains some important fixes:
Fixes
- Make RINEX 2.XX logs on single-band receivers contain only selected GNSS
- Fix deleting Wi-Fi networks with the names that contain special symbols
- Fix some cases when Reach M+/M2 turns into sync while running
- Make logs not disappear in case a Reach M+/M2 gets turned off by disconnecting from the power supply
- Fix wrong LoRa settings representation in Reach Panel if they were applied via ReachView 3
- Fix the ability to set wrong air data rates on the Base Mode tab in Reach Panel
- Fix sudden one-hour interruptions in long-time LoRa transmission on Reach RS2
- Automatically restart the UBX log if the
Raw data debug
is enabled
