Today I updated my rs2 to 2.22.1 Version, then Im connecting via NTRIP to my base but the solution was only single, two times by 1 or 2 minutes the solution change to fixed but the rest of the one hour of testing was single.
I test other reach rs2 with 2.22.0 version and it works perfectly in the same time and conditions.
A little test today I cant connect via NTRIP in places that I get fix in less than 20 seconds with the past version. Try it with two RS2, i attach the full system report.
Here are today system reports, one rs2 have an older version and works perfectly via ntrip at 50 cms near to the other rs2 that is not working with 2.23.1 version.
Just wanted to let you know that we’ve released v2.23.2 update. It should fix some issues with establishing fix via the NTRIP casters. It’d be cool if you tested it with your units to see if it helps.
I think 2.23.2 is working now to recive NTRIP but i cant make it work to transmit via NTRIP, I try to transmit with an older version in other RS2 and it works and the new version is reciving ok.
