After further exploration of ReachView, it appears I can configure two simultaneous output streams on different devices. The advanced settings section allows for a second stream out. This may be the solution for simultaneous serial + Bluetooth streams but I need to test.
Ok that makes sense. I am using USB power source. But what about my other question on the diagram regarding the serial port contention? How can i use my serial radio and stream output over the same serial port?
Reach has 3.3V TTL UART, so in order to connect to RS232 equipment you will need an UART<->RS232 converter.
Simply wire TX to your equipment through converter and RX to your radio without converter.
Ok but what about power, does the RS232 need power? The same question goes for ground? Do I need to splice ground and power since radio and RS232 need them?
Maybe the adapter I’m using has both in/out so I don’t need to splice? I know the pins I’m using in the photos are the ins but I don’t know what the second set is for.
I think that pins are just doubled. All you need to do is wire the TX to the converter and RX to the radio. But do not connect RX to converter at the same time, it will cause errors.
@igor.vereninov, What if the radio was not involved, should I still only connect the Tx from the Reach to the adapter? What’s the issue in also connecting the Rx?
There is no issue with connecting the Rx and normally you would connect both lines to the converter. I have just offered you an option how to split the port for your application.
Is there any update on this discussion? I’m very interested in the topic as I am a geophysicist. I would like to know if the EMLID Reach has a serial output option over a DB9 connector that can stream NMEA 0183 messages.
I used it with partial success. However, I’m 99% sure the issue was that the update rate on the NMEA messaging was incompatible with what the GPR expected. You cannot control message type nor rate on the Reach. I’ve added that feature request to multiple threads but don’t know where it lies on the Emlid priority list.
However, if the NMEA strings and rate that Reach outputs is compatible with your equipment, the setup described above absolutely works from a wiring perspective to DB9.
Hello
I am trying also to send cordinates from Reach RS through the serial rs232 to db9 cable connected with my GPR monitor
However I can’t get any cordinates and I tried all the available baud rates.
I just saw your post that you were facing similar situation
Any suggestion?
Thanks
