Can anyone help me with this?
I want to connect my reach module to an existing autosteer in my tractor.
This is the pinouts for it:
What do I need to make this work. I want to use a powerpack for power for the reach as the existing is 12 volt on the tractor. Will be using either a cell phone hotspot or radios for corrections
Any help greatly appreciated.
Good Morning Bide
Seems kind of silly looking at this today -20c this morning but…
You are correct the left column is from the GPS (its a 12 pin connector at the GPS) I am using now the column next to that is DB9-A (Serial A) and the next is DB9-B (Serial B).
And the deustch connector is not used in my setup.
My present set up uses DB9-A to connect into the tractor harness, the tractor harness is a DB9 female end.
The DB9-B is a male end on the tractor harness
I can use either of these DB9 to feed the gps signal in as I can select either on my screen.
You are correct at present the system uses 12 volt sent to the GPS unit. I see quite a difference in the price of those adapters any insight into them?
Also the NMEA messages I need are CGA and VTG
The GPS I use now is capable of RTK but of course these companies want several thousand dollars to unlock that and my operation is to small for that.
-20c, eh? So it’s still flip-flops and socks weather, but you probably had your sleeves and long pants on today.
I’m not going to assert anything, but my intuition says use Serial B with the RS232 to UART converter. (no, I don’t know which ones are better than others)
Is Manual Mark in even used? Maybe for marking waypoints for later retrieval after post-processing?
