Coordinate systems: datums
In the previous tip, we started talking about coordinate systems (CS), the problems of measuring the shape of the Earth, and the mathematical figures that are used to describe it—an ellipsoid and a geoid. However, we need something to help us attach all these rather abstract models to reality—to define the spatial relationship of these models to the Earth. In this tip, we will look at a geodetic datum that can help with that.
Datum
What is a geodetic datum? It is a set of data: an ellipsoid with 3-D Cartesian axes used to attach it to the real physical world.
But there’s another question. How can a surveyor access the datum if it’s something ethereal? There are so-called physical benchmarks or permanent survey marks with precisely known coordinates calculated based on the required datum. Benchmarks allow you to access coordinate systems and obtain accurate and consistent data, in other words, to perform a datum realization.
Horizontal and vertical datums
In fact, there are horizontal and vertical datums, and the reason for having two of them is convenience.
The horizontal datum is usually based on an ellipsoid. Unlike a geoid, it is regularly shaped and can be easily projected onto the surface using a simple formula. Projection is usually an essential part and the next step after applying a datum, but we’ll tell you more about that in our next tip.
The vertical datum can be based on either an ellipsoid or a geoid, but the most convenient form is a geoid. It’s simple. With a geoid, it’s much easier to get a notion of height. It’s based on mean sea level, and that way you get a zero level—it’s clear what’s above water and what’s under.
Therefore, when you set up a coordinate system in the Emlid Flow app, you have the following settings—Coordinate system, which includes a horizontal datum and its projection, and Vertical datum.
Global and local datums
Remember talking about global and local ellipsoids in the previous Support tip? The same applies to datums.
The Earth’s surface doesn’t stay the same due to natural processes such as the movement of lithospheric plates, earthquakes, and so on. The benchmarks move over time, and using a universal global datum becomes problematic. This is why there are local datums that are designed and optimized for specific areas. For example, one such horizontal datum is the North American Datum 1983 (NAD 83), which fits the shape of the Earth specifically in North America. Note that there may be several datums available for an ellipsoid.
In the next tip, as we’ve already mentioned, we will talk about the next coordinate system component—projection.
If you have questions or would like to learn more about the specified components or some other related notions, let us know in the comments below or contact us at [email protected].
Thank you @natalia.botygina ! Great explanation easily understood.
You are the geodetic guru !
Hi Bryan!
Thank you for your kind words!
Looking at the screenshot above, there is a warning to “make sure your base or NTRIP is in ETRS89.” Connecting to the base, I cannot find any setting that includes this information or ability to change it. Where is it located? My coordinate system was NAD1983(2011) UTM 12N.
Also, I am trying to combine datasets, one that was taken using GEOID12B (USGS survey) and one that was taken using an ellipsoid (my Reach survey). Is there a way to make a correction to my survey?
Hi @claire.gilder ,
Since you need the project to be in NAD83(2011) / UTM 12N, your base should broadcast corrections in the same datum. You cannot change this setting in Emlid Flow.
If you are connected to an NTRIP service and you are in the US, most of them broadcast corrections in the NAD83(2011). If in doubt, I suggest reaching out to your provider and confirm what is their broadcast datum.
Otherwise, if you have your own base and set it up over a known point, ensure the known coordinates are based on the NAD83(2011) datum.
Also, I am trying to combine datasets, one that was taken using GEOID12B (USGS survey) and one that was taken using an ellipsoid (my Reach survey). Is there a way to correct my survey?
Definitely possible. You can change the CS of your project. You can read more about it here. Emlid Flow will recompute the coordinates for you.
Also, if you need further help, please feel free to email us at [email protected]. We’ll help you set it up. Thanks!
Here in USA SC, our state’s RTN broadcasts in ITRF2014. it’s the software in your controller or data collector that coverts it to the system projection of your choice, in our case NAD83 (2011) EPOCH 2010.0000
Using our drones (Autel-DJi), we use the RTN in its native formai (ITRF2014) for imagery/LIDAR collection. We process in that format then export final computed data in NAD83 (2011) EPOCH 2010.0000 Geoid18.
Accuracies are usually 3-6 cm or less in both horizontal and vertical components if great care is taken in measurement methodology.
