Hi All ,
We are reporting a similar problem with 2.25.1
we did have it working for one set (base and rover on 2.25.1) but did not have any luck with another set.
Hi All ,
Hi @esa.attia,
We’re working on the solution now. I’ll post an update here once we have any results. In the meantime, I’d suggest reflashing back to v2.24.2. You can this guide to accomplish it.
Hi there,
I have some good news. We’ve just released dev v2.25.2, which should fix the issues you’ve faced.
I’d be happy if you let me know about the results of your new tests
Working fine in new version. Many thanks for your support.
One was 2.25.1(Dev) and the other was 2.24.2(stable). what i found that, if base is launched in 2.24.2, the other 2.25.1 can get fix but if base launched by 2.25.1, then it hardly gets fix in 2.24.1.
Any ways, we already reverted all my six Rs2 to 2.24.2 stable version and now all are working properly.
Thanks,
Regards,
Hi @abeerquddus,
This issue is already fixed in v2.25.2. So, if you’d like to work on dev branch, you can update your receivers.
@richie1aubyn Hi Richard kindly provide me your number i am from Ghana and would like to ask you few questions about the RS2 before i purchase. Thank you in advance hoping to hear from you soon
