It’s been a while since we rolled out an update! We are currently busy improving the platform layer, updating internal stuff. So today we are pushing a new dev update with several big improvements under the hood which will also improve the experience with Reach.
Fixes
Fixed LoRa is not connected message popping up on some RS and RS+ receivers.
Fixed Android app not being able to download logs or projects. Please note that you need to update both the app in the play market and your Reach for the fix to work.
LoRa radios now support complex constraints with several ranges. Russia is added to the list of countries with frequency range limitations.
Fixed a small bug with project list’s dropdown menus getting stuck in some cases.
Fixed the Wi-Fi not seeing channels 12-14, which resulted in Wi-Fi networks not being seen from time to time.
Thanks for all the feedback!
Best regards,
Emlid team
Update 04.03.2019
v2.17.2 has been pushed, fixing the bug with jumping correction input. Also added a note about fixing the Wi-Fi channels.
Update 12.03.2019
v2.17.3 has been released, fixing popup menus not disappearing in v2.17.2.
Update 23.04.2019
v2.17.4 has been pushed, fixing several Bluetooth issues on RS+/M+:
A bug where RTCM transmission over BT would sometimes abruptly stop has been fixed. This fixes the connection to both SurvCE and Android collectors
Bluetooth name change will be applied immediately, not after a reboot
Update 29.04.2019
v2.17.5 has been pushed. This release brings Reach/ReachRS in sync with Reach M+/RS+.
Well, that would make this DEV release totally useless. Wonder if this happening only on Android devices? Anyone test on Apple iOS? Do these releases get tested on Android devices or MOSTLY iOS devices?
benefactum.xyz
(Bene Factum Ingenieros Consultores Sas)
#8
Its a solid bug. Slidebutton slides on and off in the correction input and base mode menu
Its both visible in the app and browser. Stick with version prior to 2.17.1 until they fix this
hello in the morning of yesterday the apps was updated (v.1.5) and in the field it did not work well with third party apps I went to the office and saw that they would continue to update the reach rs + in my case and when I try to configure them to be able to use it the day today they did not allow to do anything and also in the browser with the ip of the team that they suggest that we return to the previous version ??
Yesterday I did two simultaneous tests with EMLID v2.17 and Promark 3. In EMLID I had only 3 green bars and a very high PDOP in the fieldgenius 10 trial version and in the Promark 3 I had PDOP less than 2 While in the moment that the PDOP indication in fieldgenius worked it started in 3.1 until it reached 13 and the Promark 3 only indicated 1.8 of PDOP with only GPS constellation. In the application of my IPhone 7 the indications are fixed but only three bars of satellites in green, the PDOP indication could be included to the next versions. I do not know what will be happening with EMLID and fieldgenius with these PDOP variations high or does it indicate zero?
SOS alert.
Versions 2.17.2 and 2.173 are not stable. The iterative process of convergence (initialization) has been completely downgraded - it lasts for a dozen or so minutes while in version 2.16.0 it is two or three minutes. I am talking about using NTRIP casters for RTK, i.e. Reach as ‘rover’ only.
Is it possible to return to the initialization module such as in version 2.16.0 or 2.16.2, possibly entering the stable version 2.17.4?
Is it really like here?:
“… the dev updates will not revert.ReachView version back to stable. You will be prompted to update to the next stable version as soon as it is released.”
RTK engine was not affected by this update. Would be great if you could share solution logs recorded on v2.17.3 and v2.16.2 showing the behavior you described.
