Hello all,
I have a problem, my base is showing a negative altitude (Zone 17R). I am not sure what the problem is. It is not really a problem as I correct it but it would be ideal if at least I had something similar to what my Trimble R8 shows.
Thanks
Reach show GNSS ellipsoid. Sure your R8 doesn’t show something localized ?
My R8 is set to measure NAVD’88.
There is your problem
Hi @hydrocynus,
Did you manage to resolve the issue with altitude?
Hello Tatiana, no, I have not resolved my issue. Let me PM you.
Hello, do you know how to convert? I found another thread but the links provided that got me to converters online are tough to use because of the the overwhelming number of options:
https://www.ngs.noaa.gov/PUBS_LIB/gislis96.html
https://www.ngs.noaa.gov/cgi-bin/GEOID_STUFF/geoid99_prompt1.prl
https://www.ngs.noaa.gov/cgi-bin/HTDP/htdp.prl?f1=4&f2=1
Hi @hydrocynus,
Any online converter should work, for example, this one.
Could you please clarify your difficulties?
Yes, this is the link I use. I will give it another try next week. More urgently, I have some money that needs to be spent soon. Can you tell me what you recommend for having the Reach RS+ on a quadcopter? I have two in mind, the 3DR Solo and the phantom 4 pro. I have already the two rovers RS+. What else do I need? Thanks! Serge
Hello,
I’d recommend checking the forum, there are quite a few integrations made by the users with both platforms:
Solo:
P4:
