Emlid Reach M+ is not saving RINEX file. From every session, I have only UBX file. Yes, Rinex 3.03 is chosen to be saved. In ReachView app there are Rinex files but there is no possibility to download them. The app shows that these files are processing with 0% progress.
I think it may be caused because of a new version of the software. Does anybody have an older version of ReachApp? Is there a possibility to install the old version? for example 2.16?
I did firmware refresh but there is only available version 2.18.1. It did not help at all.
Reach is powered from drone battery.
I just unplug the battery.
Until today (version 2.18), M+ never had a problems with saving files after turn off like that.
What do you think?
There is an issue with RINEX log processing that occurs when you shut down the unit by unplugging the battery. We’re looking into it now and will provide a fix in one of the future firmware releases.
At the moment, I can suggest 2 ways to stop log recording:
Stop RINEX recording manually in the app before unplugging the power cable
Turn off the unit using the power button in the app
As an alternative, I can recommend recording data in UBX and converting them later.
Do you know when we can expect the release of the new firmware?
So, there isn’t any chance to downgrade the version of the software? Or reflash reach with older software file? I can do it manually with Reach Firmware Flash Tool. I just need a file with f. ex. v2.16 from you. It will help me a lot… I have already 4 units of Reach M+ with 2.18.1…
I can’t provide you with specific timelines, I’m afraid. However, I can inform you once we release the fix.
Even if you reflash Reach with a previous firmware version, it’s not possible to skip the update stage. Reach automatically updates to the latest stable version after reflashing.
I’m already waiting 4 months for your update, and if it comes, it’s still the same problem. I don’t know how you can’t fix for 4 months, something that has worked for several years on your receivers … In my opinion, this is a shame.
@dmitriy.ershov
I understand … Ever since Tatiana informed me that my problem in the development release is fixed, I have been waiting for a stable version. When it came, I was ready to bet it was the update I was waiting for. I was just pissed off when I realise it’s not. I apologize for my negative tone, but I really was counting on this release. Do you have any deadlines for the next stable version that interests me?
