I’m flying a Reach Rover unit on DJI M600 pro connected via hotshoe running Reach View V.2.22.0
I have several flights that are missing ~10% of camera events after processing RINEX files with Trimble R10 base station logs with RTKPOST. Flights flown at 120 m AGL with 2 second intervals between captures.
My problem may also be unique…I am missing an event every 8-9 photos but sometimes every 4 - 5 photos and other times skipping many photos. See map below:
Hi Tatiana,
Thanks for your reply. Do you know why I would have different events in the UBX vs Rinex files? Or is there any way to retrieve the events ?
I experienced a similar issue for a very long time, more than 6+ month, tried everything, was told that the problem was from the antenna placement or the electrical quality of my plane but no luck until i tried to ignore what was on emlid docs, this part :
If your raw logs from base and rover are saved in .ubx format you should convert them to RINEX. If you already have RINEX logs from the receivers you can skip this step.
Using only the UBX files, I never missed an event since and I just tried today to use the RINEX logs from a recent flight and I lost 23 events even when using 2.22.2 on the RS/M+ combo
Please Tatiana update your docs with :
If your raw logs from base and rover are saved in .ubx format OR YOU HAVE A PROBLEM WITH EVENT NUMBER you should convert them to RINEX. If you already have RINEX logs from the receivers you can skip this step.
We thoroughly tested time marks logging on Reach M+ devices earlier. Unfortunately, we weren’t able to reproduce such behavior while working with stable configurations from above. I’ve written about it here:
May I ask you to try one of the configurations I shared above and then post the logs here? I’d like to check if the issue persists.
