Hi Benjamin,
Sorry for the delayed response.
We conducted several tests with UBX and RINEX logs recorded simultaneously on the Reach M+ device on the latest stable release. However, no matter which format of raw data we used, both *_event.pos files contained the same quantity of time marks in the result.
That’s why I don’t think that the format of raw data could influence the time marks missing somehow.
May I ask you to clarify some things so we can investigate deeper?
- Which firmware version is installed on your Reach M+ device now?
- Did you record logs both in RINEX and UBX format simultaneously and then tried to PPK both of them: RINEX recorded on Reach and RINEX converted from UBX?
- Could you please share both these files (UBX and RINEX) so we can check them and try to process?
Thanks.
