Can’t create Rinex files with rtkconv.exe. I took raw .ubx files and tried to convert. No success. I changed format from auto to u-blox still no success.
Using teqc, I was able to convert .ubx to .obs but not .nav.
teqc command:
..\..\..\GPS\teqc_mingw_64\teqc +obs + +nav +,+ -tbin 1d gitalong_base raw_20161112*.ubx
But it’s my first time using RTKCONV so maybe I’m doing something wrong. After clicking Convert, no files are written to disk.
Hy
try to change format into U-blox not auto
Francesco
Tried that too. Are you able to successfully do it?
Also, should I always get a .nav file for every .ubx? In other words, is this a true statement?
ubx always yields obs + nav?
Yes
but maybe you have to use the latest rtkconv because of some changes in the format for m8t messages
Which version is that? I thought I had the latest from: http://www.rtklib.com/
download the latest files and copy on your directory
Ok, 2.4.3 beta fixed this issue.
surveycol
(Surveycol)
September 28, 2017, 3:59am
#10
HI in rinex convert, the signal from the satellites is very fragmented.
it is possible to solve?
