Antenna is spiral GNSS L1 from Stoton factory.
About installation - it is not easy ((
Our engineer spends a little more than five hours installing equipment into a copter.
There is a high probability to break something if you are not a professional.
But we will help AShot buyers to install it and GNSS equipment to DJI Phantom 4 adv|pro.
Thanks for reply. Found antenna on aliexpress for 75 bucks. It has different name tho, but I guess same antenna sold under different names. Price seems reasonable if you want to get neat Phantom 4 RTK-like design.
Ok, I guess I’m sold, because Phantom 4 RTK where I live costs almost 4 times more than what I would spend on Phantom 4 Adv+Ashot+Reach M+antenna. Idk about other people, but for me neat design is extra selling point. Ordered Ashot, looking forward for delivery and instructions.
in Phantom 4 pro there is enough space for Lora radio installation.
But I dont see the reason to install it, becuase you will need to stop in each photo for 3-5 seconds to receive FIX with RTK.
Yes, but you won’t see much of an advantage and will probably end up PPK anyway. It is nice though that with the Emlid setup you can run both and still have that option.
Unlike the DJI P4P RTK. You have to turn off RTK in there system in order to get all the info you need for PPK. Plus, if you are relying on the RTK to fix the entire time and aren’t doing any PPK then you will be upset when the RTK fix drops.
Hi everybody.
We received flex cables from factory and ready to start shipping of AShot board for PREorders.
Shipping starts next week. Sorry for delay.
Today I will show you how to install AShot to Ph4pro. Now I am working on AShot installation manual.
Lol. I have already asked Konstantin about possibility. He says that it is not possible, cause you need timemark connector, which only available in new M+ modules.
Ashot don’t know really well emlid product in that case
Hardware is the same for ublox m8t where T means it have time mark. Emlid already make timemark pin in their connector even if they are different between v1 and m+.
V1 have Intel Edison inside whereas m+ was built with emlid neutis n5 when Intel stop Edison production. They share the same operating system “yocto”. I used time mark on v1 and m+ and they work in the same way …
Nice manual and beautiful teardown pictures, but I think you should add a hint that people should take care of electrostatic discharge. I also did not really understand what you do with the ribbon cables but I guess that is because I only look at the pictures.
