I realized this a while ago, but it’s only when I finally decided I wanted to use the RINEX log today that there is a very weird shifts in the data logging date. I did a survey today (may 13th 2021) and all the logs are recorded as November 16th 2020… six months ago.
See attache .obs file. The logging was from 10:55 EST to about 19:20 EST… so it is a bit more thant the shift to UTC.
So I just updated the Firmware version to v26.0 and the time sync seems to have done something, but still, the record date is April 2 2021… one month ago.
Since I am new on the forum, I cannot post .obs file or a screen picture of the reachview app showing these problems, but I can also provide them for help.
Please share the Full System Report from the unit with me. This tutorial describes how to download it from the unit.
Please note that Full System Report contains sensitive information that should not be shared publicly. So please send it to me either via PM or through the support@emlid.com.
Seems like new forum users can’t upload documents (I had to create a new login as I didn’t remember my previous one), so here is a link to the data I extracted from the base on Google Drive.
Just wondering if anyone can give me an update on the problem? Yes I can use the units in the meantime, but at one point this will still be an issue for PPK base positions…
Thank you
The issue with the wrong date of the logs is fixed in the new Reach Firmware 26.2. You can find the full list of fixes and improvements of this update in this community forum post.
Please update your receivers to check if the update works for you. Please let me know the results of the check-up.
