Hi @chiz ,
Let me comment on the issues you’ve experienced below.
As has been already pointed out, the default password for the Reach’s hotspot is emlidreach
. You can check it in our online documentation. You can also change the default password to any you prefer in the Wi-Fi tab of the ReachView app.
Good to know you were able to connect to the receiver! We’ll add the info about turning off the mobile data prior to connecting to the hotspot to the docs.
Thanks for noticing it! We’ll fix the link shortly.
All of the network scanning utilities can be found in the First Setup guide.
To find out Reach’s IP in the network, you can use the ReachView app or one of the following utilities:
- " Fing " app for iOS or Android
- " Nmap " on Linux/OS X
- " Zenmap " on Windows
This mainly depends on your OS and the smartphone. Usually, on Android devices, it’s more likely you will find the survey file in My Files/Downloads
or in My Files/Internal Storage/Download folders
. You can find more information about downloading files from the ReachView app in our online guide.
As Michael has mentioned, this might be due to the fact that Windows suggests entering the PIN from the router label to connect to the network. Please choose Connect using a security key instead option. Then it should be possible to enter the emlidreach
password of the hotspot.
This and other tips on how to connect to the hotspot of the Reach receiver can be found in our Quickstart guides: First Setup and How to download files from Reach.
We usually reply within one workday as stated on our website. However, it might take longer to understand the issue.
You can connect the receiver to the hotspot of your device. Then, you can use the mobile network on your phone and connect to the receiver without switching between the networks.
You can find out more about using your phone’s hotspot with the Reach receiver in the Setting up Wi-Fi section of our First Setup guide.
Would you mind describing the issue in more detail? Have you collected all 50 points in one survey project? Do I understand correctly that you can’t access the project in the ReachView app? How many points are there in the exported project?
Could you please share the firmware version that you’re device is running on? You can check it in the upper right corner of the ReachView app next to the battery charge level.
