Using Reach for landsurvey and more
Just upgraded my pole with tablet holder for cars, and a soft case for my phone. Glued the case to the rig.
Now i can focus at getting the job done and not be afraid of losing stuff to the ground :slight_smile:
Is this a tripod or monopode ?
I made survey with triggering an interrupter which log my waypoint on reach like hotshoe flash
Neither? I guess mono is the right term, but i have a tripodversion for base
Its a teleshaft for painting etc
http://www.jordanvethvordan.no/produkter/verktoy/forlengerskaft/ultimate-ekstra-langt-forlengerskaft-115-270-cm~p14455
Do you have a link to this setup of your?
Not yet but I will post when I have time …
So what I don’t understand if you use monopod is how could you stay recording your survey point with it. It’s impossible. In the past I used Trimble equipment with bipole like this :
Do you have a bubble level embeded ?
But this mono-bi-tri-pod are very expensive. I try to low cost this
Ok, i see. Are you surveying in other modes, static?
I usually dont spend more time then few seconds during stake out or collecting points.
If i for some reason need to stay longer i use a tripod with 3 adjustable legs (this one).
Both setup have bubble level. Pictures of setup further up this thread.
Are you thinking about accuracy when you say its impossible?
