Hi, new to this forum
Just bought Reach kit (backordered of couse, but hope you stock them soon?)
So, in teory i think i can get this to work.
Pri.1 is to get the rover give me a location/reference value from one point to another on the field or on a building site.
2. Map locations/points from survey to CAD program for reference and personall control over coordinates
3. Run log directy on another software like autocade 360 or similar, Ref this site - http://gpsworld.com/rtk-on-a-smartphone-running-autocad-i-did-it-last-week/
This is it for now, i`ll update this tread as i probably will have a bounch of questions and share experience
Reach center point of coordinate is measured at center of the antenna, The x and y axe?
And the Z value is at the bottom of the antenna, around the socket?
3.Z value, or height. Is the the heigh from Earth ellipsoid? or corrected to local sea level?
4.Converting or applying local datum to ex. Euref98 wgs84 UTM32, Real time UTM32 output?
Hi, havent found where the center of position Reach is. Does anybody have a spec for this on the antenna module?
And a second question, is it possible to set an offset to base coordinates? Couldnt find that either. Btw, got my reach kit today, and im so exited to start digging into its features.
I`m not sure i understand. But I wish to place my base at a known position with coordinates, but at that spot there is no gps signals so i have to manually ad an offset to the nearest position with gps signal. It is just a couple of meteres away.
Obviously if REACH could do an offset, the bearing and range would still need to be measured. The REACH would have to use the formula like in the above conversion (Vincenty formula) to come up with the new COORDS anyway.
There are other formulas and programs to do this but this works for me without using mapping software.
Thanks for great tips.
Still, i need to do it simpler then that in the field. Bare with me for a second and show you what i mean.
We use X/Y coordinates which is metric unites and easy to understand and apply directly doing field survey.
All post and after processing is done in Archicad,so its easy to calculate A to B and so on. But working with fieldsurveying, and on site we usually have at least on known point which we could refrence/measure from.
The scenario is, we need to find or set out points/marks on the ground where a building should be based on existing refrence point nearby. And in Archicad we have a drawing with the same refrence point and our building with a certain distance, so, all fine until we get to the site and there is no gps coverage or there is an ubstacle that force us to move our base and therby alter the value we had from refrencepoint to building.
What we have done before (see fig. below) is
get a fix as close to refrence (P0) as possible
use a measuring tape or similar and strech this out from P0 and a good distance out, lets say 5meteres. (that gives us a straight line from P2 to P1 and with distance, also P0)
then we get a fix on P2. ( P2 would be 5m from P0 , they value shown on fig is wrong in this case, it was just an example.
Now we have distance from P0 to P1 and P2 and could find X and Y offset values from P1 to P0.
And with offset values added to refrence point P0, Reach gives us βrealβ distance from P0 which is the correct distance we would work from.
Yes, we could take this value and recalculate every measure from P1, but this more post work and more driving back and forth. We also face multiple points on site where we need to do this.
So, if anybody has an easier way to go around this, please let me know.
there is a survey peg with a known lat long on site
the survey peg was used as the origin in ARCHICAD for the building
4)The plan was to then use REACH navi to mark others point for the build using the x,y from the origin (I have not yet used reach by the way but I assume a realtime navigation function could do this) with the base over the known survey peg.
the survey peg has no Gps coverage
6)need to move the Gps station to a diffent location and subseqently all the measurements is ARCHICAD will now be out.
I thought ARCHICAD the origin could be reassigned or move the entire model by the offset amount? Is this correct? Or am I missing something?
Yes, it could be but not always. It could also be manhole, roadsection, corner of a house and so on.
not nesecerally, we usually have access to digital maps. .sosi file that contains road, fence, borderline, lightpole, other houses and so on. This is imported to Archicad and placed on a worksheet with precis coordinates, and then we place buildings according to this.
yes, more or less
The peg could have gps coverage, but often it is close to a building and we need to move few meters away to get better reception and/or sometime its hard to fysically plase base station into a wall or building. Or impossible.
Yes.
And yes, everything is simple to change in Archicad but not when er are in the field were we dont have Archicad
With offset this could be used both ways. 1 to use with uknown refrence point or 2. to create a peg/point in the terrain that has no gps coverage or is in such a bad place.
NB! this post has som funky bug with the numbering of post that i cant figure out.
I just had a brief look at the RTKNAVI windows version - I think if you play around with the antenna delta offset settings in the options tabs I think that may help what you describe.
I have not done this myself but if you offset the antenna it should work.
Addit: I after playing with this - it is quite easy, under RTKNAVI>Options>Positions - Base Station, Set the base station coordinates as your datum or the origin in archicad, Now the the crux --> Tick the antenna type (leave blank unless you have antenna calibration file) then adjust the (E)astings (N)orthing ie X,Y difference from your datum/archicad origin.This differences have to be in the North and East grid directions.
I have been using the Reach a lot recently. I have just got back from a very big survey job, measuring ground water monitoring well elevations with the Reach. The spread of well locations was fairly large with many obstructions about. NTRIP was not an option as the closest CORS was 150km away. So I post processed all 90 odd observations, each observation lasting 30seconds. Each point was cheacked by a third Reach device. The results were as always excellet with a maximum difference of 15mm between solutions.
But this mission of post processing 180 individual files lit a fire under me to get testing with the bluetooth ouput solution. I found really good results with the following combination:
Setup a base Reach and issue RTCM data via RFD900 radios
Setup second Reach in single mode to act as a backup base to use for post processing data if the communication in the field goes down.
Setup a third Reach in rover mode on a plumbing pole with attached RFD900 radio to recieve corrections. Th solution should be outputted to Bluetooth NMEA.
Then on your Android phone:
Use Mobile Topographer Pro (https://play.google.com/store/apps/details?id=gr.stgrdev.mobiletopographerpro) to store, import, and stake out points as well as moving data. The app is pretty great with on the fly CRS translations, the abliltiy to apply offests, name points, and export to a variety of formats.
I think using this combination, we have a fully functioning Land Surveying tool.
For sure, multipath is an issue, not just with Reach but with all L1 only receivers. Not just buildings but any elevated structures like trees, fences, etc. Remember that Reach has been designed for aircraft where multipath is almost non existant. But on the ground, you just have to be more careful of where you measure, and use your brain a bit. If the software tells you that you are getting a 0.01m fix in an urban jungle, there is something wrong, but over time RTKLIB will identify this and recalculate an more realistic answer.
I recently measure a site for groundwater monitoring borehole elevations and had to include the building corners on my plan. I just lifted the antenna on the pole on top of the building corner and did my observation as normal, noting the height difference by measuring with a tape measure from the antenna to the ground.
The trick is to have long observation windows, do them in open places, have your base in an open place, use a ground plane and check your measurements. Following these will give you greater piece of mind and accurate results.
Luke,
Thank you for posting your experience in setting up your surveying system. I would like to ask you to explain further why you used the 3rd reach device and how it worked out for you?
Another question, how can I output via Bluetooth to my iPhone/iPad since I do not have a droid device?
