I am curious, if one is utilizing the Emlid Flow app for NTRIP connection to RTK, can they still benefit from the RS3’s tilt corrections via a Bluetooth connection to ArcGIS FieldMaps or Survey123?
Or am I optimistic about the integration with ESRI?
The RS3 can be connected using Bluetooth, TCP, and serial. Starting from the 32 version of firmware, you can stream NMEA messages with tilt compensation.
