Very good suggestion!
Orto out from a defined line is much needed!
Stake out is good,but not enough!
Turning off RS+ from the RV3 app doesnt seem to work. The receiver stays on.
Also, older RS units, you must hold the power button really long to make it shut down⌠like 15 seconds or more. All other units shuts down after 3 ish seconds.
All runing the current versions
Our RS2âs are about 3 seconds on and 5 seconds off.
Ja, that sounds about right and normal for the RS2
Hi @TB_RTK,
Did a quick test and seemed to catch the same behavior with 28 Beta 1. Are your devices on the Beta too?
Do you link it with the update? I think it may be a bit harder to reproduce, so can you share the full system reports at support@emlid.com?
Hi TB_RTK,
I have an RS+ with similar problem, but in my case the receiver donât restart, it power off and then not restart, stay off. Iâm working RW3 v6.10 in FW 27.1, but now donât find the issue.
Yes
I`ll report back on the other question
Updated one RS+ unit to 28 beta 2, shutting it off from the app is now working
Hi Bernardo,
There are indeed some issues with rebooting and shut down via ReachView 3 on 27.1. But, as @TB_RTK just confirmed, itâs solved in 28 Beta 2.
These changes will be moved to 28 stable, of course. But if they are crucial to you, you can subscribe to Beta. Just remember that we donât recommend using Beta versions for important fieldwork.
Minor quirk.
-Pole height isnt kept within the project. If I change the pole height in a different project, going back to a project make me set the pole height again. Somewhat cumbersome working with benchmark and other stations that is not a pole, but a measured distance to the ground.
-Save all projects. A way to backup or save all projects would be nice in case loss of device or failure.
Hi @TB_RTK,
Valuable comments. Weâll take a note!
Is there any news on the update of the stakeout function?
Hi @step,
Itâs at work. Itâs not the most straightforward task to implement, but be sure we didnât abandon it.
is the âsave to manualâ coordinates on the base station page removed?
I remember having this option in previous versions of RV3 but in the recent versions is it removed? The option is still in RV2.
Hi @vgo195,
Yes, we temporarily removed this feature as it requires reworking. It will come back in future versions of ReachView 3.
A post was split to a new topic: ReachView 3 update feedback
Olå. Eu baixei hoje mas o app não abre mais. E tenho um trabalho neste telefone (android). Eu deveria desinstalar o app e novamente ou esperar a próxima instalação o projeto que ainda não descarregado para perder?
Tive o mesmo problema (comentei logo abaixo)
Hi @joaovitorlara8,
No need to reinstall the app, just update it to the latest version. Weâve fixed the issue there! Through update, youâll keep your projects and the appâll open without any issues.
I can see from your comment in another thread that the issue is indeed resolved for you with the update! Thanks for this update
Is this fixed?
