Thanks to @bide for breaking the ice about Reach RS
Im just another lucky user to recive a pair of RS units, no strings attached.
About me:
No survey grade, my first experience was Topcon GRS1 in 2013 i think, and from there i learnd everything on my own.
My daily work is CAD operator (data animated construction) and site planing. Using tools like Archicad and Architerra.
I discovered Reach when looking for return to home function for my model airplan and started digging into features of Reach.
I will updated this thread as i progress learing this devices inside out, picking it apart and with great risk of damage it (i hope not) , but my car-ma has left the building.
From this point and on i assume you are more careful then me. Any copycat action is at your own risk.
Now, lets digg into Reach RS and see what its good for.
First long range test with LoRa i did with 10dB. Center position on mobil topomap is base, two others are at rover.
A bit quick on the screenshot trigger as it captures the Age of diff a bit soon, it dropped few seconds after this.
BTW. Age of differential changes to red above 5 seconds.
Im also looking forward to see what Emlid i cooking together regarding COGO, saving/loading points and all the other features thats been writtan about.
Did a driving test with rover hanging inside the car on the head support thingy, and the antenna vertical. Base mounted on my fixed point with 6dB output on the LoRa. This antenna pointed out horizontaly.
Poor satellite signal of course but manage to get 1,4km distance from base @ lowest dB output on the base.
Thats not bad at all. How many mW are we talking? 4 mW and 1,4km range!! Or 0.0039 W.
