When I do static method, for a few minutes could get fix. Then i was waiting for a few minutes for collected points. Then i tried to move the rover, the point move very slow. Then I stoped the observation after that.
My question, can we use static method for collecting with moving mode, sounds like kinematic (moving) but static method. (Rapid static)
I’m still have no time for observe more detail.
@igor.vereninov @egor.fedorov @bide @emlid
If positioning a non moving point you get mor accurate measure with static.Kinematic mode is much faster hence used with moving object but you get less accurate measure but accurate enough in cm range.
If you use static mode while moving you could get real bad measures because static mode dont keep up with the constant chang in location.
Other unit have rapid static function, Reach dont.
A post was merged into an existing topic: ReachView 2 beta Suggestions/features request
