Very good thanks !! I have a solar system charging by USB 5 volts 2A. Now I am charging it with my iPhone
I have to buy another voltage regulator for the solar panel with two USB outputs.
good idea I think i will get me one of these https://www.princessauto.com/en/detail/5000-mah-solar-power-station/A-p8829673e
I have a 20 watt solar panel that I am going to make a base power system. Gel battery 12 v 7 amper that will be connected with the CBL101 cable
Hi @agrimgalina,
We aware of the issue with a stakeout and preparing the hot fix currently.
I’ll inform you once we release it.
Sorry for the inconvenience and thanks for the report!
@tatiana.andreeva full report
Can’t wait!
yes Tim !!! wait
Hi Luis,
Stakeout tool works again in v2.20.7
@dmitriy.ershov thank you Dmitriy for the assistance
Yay!
Looking forward to seeing your entry!
Yes I will, but I want to make a publication with the exactness achieved with points of the geodesic network. it will take a while …
@dmitriy.ershov Using the RS2 in ntrip I had a problem when the data signal of the cell phone is lost and FIX remains very high age and never goes to floating or single, it is something that should be verified by EMLID.
similar question??:
Hi Tim, having no data signal on the cell phone that gives fix but not 90 seconds, is there! It’s very similar, this never happened to me with Lora in my RS +
Hi Luis,
May I ask you to share the screen recording of this behavior?
Hi @tatiana.andreeva only when the age is 50 becomes floating, remains fixed
