Hey @erro.alfaro88
I share your frustration.
I have been experiencing similar results that seem to be getting worse & worse. Today I dedicated my entire day to troubleshooting and I am no closer to a solution.
The LoRa radios continue to be a source of contention and the weak link in the Emlid RTK architecture.
I have owned 3 x RS2 receivers, 1 x RS2+ and 2 x M2 receivers so I have a clear idea of how these machines work.
At present, I cannot achieve a Fix beyond 100m baseline - with a clear line of sight and clear view of sky.
I have already exhausted the problem with Tech Support via email and they have not been any help.
The set up I am using is a RS2 & RS2+ as Base & Rover respectively.
When I started using these 2 receivers I was getting an optimal range of up to 1 km in very sketchy circumstances. Over time the range has just gotten worse & worse and now it is at an all time low.
Switching them around has not improved the range. Changing the radio parameters has not improved anything. Today, I even tried using them without the OEM LoRa antennas 1 at a time to see if perhaps one of them had a busted antenna connection. The range reduced to 10m so I guess that is not the problem.
I have tried aftermarket antennas, that seemed to improve, but not for long.
There is only 1 thing left to try and that is to re-flash the firmware on the Base receiver (I already flashed Firmware on the Rover last week).
Hey Tim
I bought the M2s to make a base station (which i still havenāt done) and also to be used as a back up field system if needs be.
I have a single LoRa radio.
I have tested these systems but they are not in every day use.
I made reference to them simply to point out that i have a functional knowledge of the Emlid RTK receivers.
In my testing, the M2s worked well.
I have not used them in some time as the circuitry for the Metta housing that I bought to be used with the M2 went bad.
I agree with you- very odd results.
My last experience with Emlid customer service was disheartening since I was made to feel that because the conditions were not perfect, (there were power lines & trees visible in the photos I sent) then these could have been at least partially responsible for the poor range. The site had clear line of sight and clear of the sky. I donāt see how any real world situation could be better than that. I was not able to achieve a 70m fix that day
I have considered that as a possibility.
I have also noted that I am no longer able to connect my mobile devices on Emlid Flow via bluetooth
Also, the Emlid Flow wifi connection ādisappearsā after some time.
In order to reconnect, you have to restart the receivers.
Very odd behavior
I plan to use the M2 as an independent check.
However, I donāt have a suitable housing at present so field testing is a bit clumsy hence my delay in doing so
The power lines and trees were not in locations that should adversely impact on GNSS observations. They were visible in the photos, but where the difficulty was observed getting Fix measurements was unrelated
This is my early days of the M2ās, I was using the helical antennas at first, then I bought the NGS calibrated Harxon antennas for both. I had the receiver and small battery in blue bag. I still use this setup occasionally. Iāve got the Lora radioās also. They provided pretty good range about 200m through dense woods, a little longer in the wide open. I think our terrain and woods was a factor in the range of the Lora, but Iām satisfied with the product. Iāll have to break them out of my āoffice of knowledgeā (aka, āoffice of many thingsā) for a project in the future.
Exciting Discovery
I flashed the firmware on the RS2 and no improvement in the 100m range between RS2 & RS2+
So today I fired up the old M2. I intentionally did not allow it to update the firmware to 31.8 - So it is stuck at 31.2.
I was able to get a FIX from BOTH the RS2 & the RS2+ (using each as a base at over 200m).
I would have ventured further but no need since the respective RS2/RS2+ Rover had lost Fix at 100m during the same session.
Does this mean the problem is with Firmware 31.8?
Emlid, I really wish there was a way to reverse the firmware updates to the previously functional one. Please make this a feature of Firmware Flash Tool software
Was going to suggest that also⦠reason being is why is this issue happening across ALL the devices and other users devices? Too coincidental? So was thinking the common factor may be the firmware?
Glad you are able to test things!
So Iāve just successfully achieved Fix solution over a baseline exceeding 500m
Using the M2 on old firmware as a base.
I should note that these receivers can top this baseline distance, but the topography here would not allow for longer line-of-sight.
Used the RS2 & RS2+ as rovers simultaneously getting almost identical results. Emlid Developers - Please make it possible for us to roll back firmware
This will allow us your loyal customers to reduce down-time and to help troubleshoot problems such as this quickly.
Thanks in advance.
Reading between the lines could it still be a transmission problem specific to the RS2 device you updated, e.g. the 31.8 update could just be coincident?
Good job pursuing this one.
All this is strange as we just used 4 RS2s with 31.8 for almost two weeks in the field and got ranges of >500m with no issues (except a loosely screwed in antenna on the base once that reduced the range drastically).
We even had less than optimal sites with no direct line of sight (small hills) and had communication at >300m.
I agree. It is extremely strange that some users are enjoying these results while others arenāt.
What you have been experiencing is what i expect from this equipment.
