how is this solution
What are you trying to achieve?
Kenapa shapefile saya tidak dapat dibuka di arcgis(Indonesia)
Please write in English, so everyone has a common language. (You could use google translate before posting)
why after update 28.4 i can’t open shapefile in argis
I haven’t check your data but I have noticed issues in reading the shapefile exported from the android ReachView 3 in ArcMap 10.7.1 and ArcGIS Pro. I’m able to view the points but unable to view the attribute table as it fails to load, The same shapefile and attribute table loads correctly in QGIS though.
I suspect this is because the ReachView 3 export includes non alphanumeric characters (full stops “.” and spaces " ") in the shapefile field names.
An option is to use the “feature class to feature class” tool, this will copy the shapefile data to a new output and will force legal fields names so the attribute data can be displayed.
Here are some links to ESRI references on the topic:
Field names need to adhere to certain conventions for them to be valid. Keep the following guidelines in mind when you name a field:
- Spaces and certain characters are not supported in field names. Special characters include hyphens such as in x-coordinate and y-coordinate; parentheses; brackets; and symbols such as $, %, and #. Essentially, eliminate anything that is not alphanumeric or an underscore.
- Be sure to edit the field names in delimited text files or other tables to remove unsupported characters before trying to use the files in ArcGIS.
- Avoid starting field names with a number or an underscore.
Hi @sahatmanikesri,
Please share your Shapefile for a closer look. Which coordinate system do you choose in ReachView 3?
Hi @sahatmanikesri,
For now, ReachView 3 Shapefile export is tailored for projected coordinates. We’re planning to support geographic coordinates as well, but the implementation will take some time. Once there’s any news, I’ll post them here.
how can i download my work from archive on computer
Hi @sahatmanikesri,
The available ways of saving or sharing the data from ReachView 3 depend on the device’s file manager. Do you face difficulties sending the data to a PC?
Yes
Simple system report
app version: 29.0.beta.1-dev-r19
current_network:
ip: 192.168.42.1
security: wpa-psk
ssid: Sahat-Base-reach:8E:8F
enabled: true
mode: hotspot
base_mode:
base_coordinates:
accumulation: 5
mode: single-and-hold
output:
io_type: serial
settings:
lora:
air_rate: 9.11
frequency: 923000
output_power: 20
ntripcaster:
mount_point: REACH
password: '***'
port: 2101
username: reach
ntripsvr:
address: 103.22.171.6
mount_point: ''
password: '***'
port: 2001
serial:
baud_rate: 115200
device: ttyEXTS0
tcpcli:
address: localhost
port: 9001
tcpsvr:
port: 9000
rtcm3_messages:
message_1004:
enabled: false
frequency: 1
message_1006:
enabled: true
frequency: 0.1
message_1008:
enabled: false
frequency: 0.1
message_1012:
enabled: false
frequency: 1
message_1033:
enabled: false
frequency: 0.1
message_1074:
enabled: true
frequency: 0.5
message_1084:
enabled: true
frequency: 0.5
message_1094:
enabled: true
frequency: 0.5
message_1124:
enabled: true
frequency: 0.5
message_1230:
enabled: true
frequency: 0.1
bluetooth:
enabled: false
pairing:
discoverable: true
no_input_no_output: true
pin: '***'
correction_input:
base_corrections:
io_type: ntripcli
settings:
bluetooth:
send_position_to_base: false
lora:
air_rate: 9.11
frequency: 923000
output_power: 20
ntripcli:
address: 159.89.221.86
mount_point: MP4916b
password: '***'
port: 2101
send_position_to_base: true
username: sahatmanikesri
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 10001
tcpsvr:
port: 10000
device:
night_mode: false
privacy_policy_accepted: true
role: null
rv3_banner_shown: true
usage_analysis_accepted: false
logging:
logs:
base:
autostart: true
format: RTCM3
started: true
raw:
autostart: true
format: RINEX
rinex_options:
logging_interval: 5
marker_name: null
pole_height: null
preset: custom
satellite_systems:
beidou: true
galileo: true
glonass: true
gps: true
qzss: true
sbas: false
time_adjustments_enabled: false
started: true
version: '3.03'
solution:
autostart: true
format: LLH
started: true
settings:
debug: false
interval: 24
overwrite: false
simultaneous_logging: true
network:
tcp_over_modem: false
position_output:
output1:
io_type: bluetooth
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
output2:
io_type: tcpsvr
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
positioning_settings:
elevation_mask_angle: 15
glonass_ar_mode: false
gnss_settings:
positioning_systems:
beidou: true
galileo: true
glonass: true
gps: true
qzss: true
update_rate: 5
gps_ar_mode: fix-and-hold
max_vertical_acceleration: 1
positioning_mode: kinematic
snr_mask: 35
sound:
mute: true
volume: 0
Help me
current_network:
ip: 192.168.42.1
security: wpa-psk
enabled: true
mode: hotspot
base_mode:
base_coordinates:
accumulation: 5
output:
io_type: serial
settings:
lora:
air_rate: 9.11
frequency: 923000
output_power: 20
ntripcaster:
mount_point: REACH
password: '***'
port: 2101
username: reach
ntripsvr:
mount_point: ''
password: '***'
port: 2001
serial:
baud_rate: 115200
device: ttyEXTS0
tcpcli:
address: localhost
port: 9001
tcpsvr:
port: 9000
rtcm3_messages:
message_1004:
enabled: false
frequency: 1
message_1006:
enabled: true
frequency: 0.1
message_1008:
enabled: false
frequency: 0.1
message_1012:
enabled: false
frequency: 1
message_1033:
enabled: false
frequency: 0.1
message_1074:
enabled: true
frequency: 0.5
message_1084:
enabled: true
frequency: 0.5
message_1094:
enabled: true
frequency: 0.5
message_1124:
enabled: true
frequency: 0.5
message_1230:
enabled: true
frequency: 0.1
bluetooth:
enabled: false
pairing:
discoverable: true
pin: '***'
correction_input:
base_corrections:
io_type: ntripcli
settings:
bluetooth:
lora:
air_rate: 9.11
frequency: 923000
output_power: 20
ntripcli:
password: '***'
port: 2101
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 10001
tcpsvr:
port: 10000
device:
night_mode: false
role: null
logging:
logs:
base:
autostart: true
format: RTCM3
started: true
raw:
autostart: true
format: RINEX
rinex_options:
logging_interval: 5
marker_name: null
pole_height: null
preset: custom
satellite_systems:
beidou: true
galileo: true
glonass: true
gps: true
qzss: true
sbas: false
started: true
version: '3.03'
solution:
autostart: true
format: LLH
started: true
settings:
debug: false
interval: 24
overwrite: false
network:
position_output:
output1:
io_type: bluetooth
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
output2:
io_type: tcpsvr
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
gnss_settings:
beidou: true
galileo: true
glonass: true
gps: true
qzss: true
update_rate: 5
snr_mask: 35
sound:
mute: true
volume: 0
Hi @sahatmanikesri,
ReachView 3 is a native app, so you can open it only from an iOS or Android device. To transfer your data to a PC, you’ll need to send the files from a mobile device manually.
If I’m missing something, please share a screenshot showing the issue. It’ll help understand what can be wrong.
Hi @sahatmanikesri,
We’ve added support for Shapefiles with geographic coordinates in the new ReachView 3 version 7. When you work with Global CS, you can choose the Shapefile (Global) option on export to upload the file to GIS apps. Please share your experience if you try it out!
Hi @sahatmanikesri,
The file looks good, and I’ve checked it opens in QGIS correctly. But the issue can be related to specific ArcGIS requirements, as David assumed. I’ll talk it through with the team to see what we can do from our side. Can you share a screenshot of what happens when you try to import this file?
By the way, have you tried David’s suggestions? Do they work for you?
I’m still thinking why on apps reachview2 my shapefile can be opened in arcgis.
while the resulting RV3 shapefile can’t be opened in arcgis
