A quick work around is to use the “Feature Class to Feature Class” tool, This creates a new file that the invalid characters in the field names are removed from.
I’ll check the SHP file you shared. But just want to ask: did you clarify the ArcGIS requirements for SHP files? What files do they need to be in the ZIP archive?
David @david.burlace, wow, nice catch! Give me a bit of time, I want to check it as well
sorry but that’s what arcgis gives.
may i be given an application for rs2 data processing because i am having trouble downloading the application(RTK or something else
I’ve checked both files and can see what David @david.burlace was talking about. The file from ReachView 3 indeed has dots in the column names. And based on my little research of the error you’ve faced, they indeed may be the root of the issue.
I’ve opened your file in QGIS and renamed all the columns so they wouldn’t contain dots. Can you try to upload this file? I’ve attached it to this comment.
This shapefile loads into ArcMap and ArcGIS Pro for me without error.
Worth noting that ESRI’s documentation says that spaces are unsupported in field names, They may cause unexpected behavior with some tools; an underscore is a safe alternative.
Thank you for testing! I’ll share these findings with our devs. That’s the question of compatibility, so we’ll check what we can do here. By the way, don’t you know why ArcGIS have such restrictions?
That’s also cool that you’ve shared a workaround! I believe it may be of great help for some ArcGIS users. And I agree with Gabriel @Gabriel_C – working with CSV files may be a solution as well.
In the last update of Emlid Flow (previously known as ReachView 3), we removed the dots from the column names in SHP files. So now ArcGIS software should read the attributes table for SHP files from Emlid Flow like a charm.
Feel free to test if it works smoothly for you and share the results.
