Hi, with the latest update and the hxgn smartnet network I don’t get any fixes, before it worked. The solution status goes from single to none all the time and the base disappears.
Have you checked the “send position to VRS” in the Correction Input tab?
Looking at your, from 10:16 to 10:19, all looks fine, but after that your SNR becomes quite bad, tilted antenna maybe?
PDOP’s looks good except for GAL in the beginning.
For some reason you have no L2C obs in GPS, which will explain your inability to obtain a quick fix, maybe?
I’ve checked the logs from the receiver. The solution during the survey was in Single status most of the time - 84%. It might indicate that the receiver couldn’t use the corrections in that time period for some reason.
Please share the screenshot of the Correction Input page when you connect to the NTRIP service. Also, please specify what RTCM3 messages your NTRIP caster works with.
It’d be of great help if you could conduct the test with enabled NTRIP service and record logs for 15-20 minutes with the Raw data debug option. You can enable this option in the ReachView Settings tab. After that, please share these logs with me.
Do I get it right that you have connected to the same mount point you’ve used before the update?
Hi @liudmila.slepova, I sent you a message with log. I connected to the same mount point and it doesn’t work. The message is RTCM message 3.x (Compact)
We’ve released a new firmware update v2.24.2. It should improve the overall stability of solution calculation with NTRIP. You can update your receiver to it by clicking on the respective note in the Status tab.
