i need to build custom wiring to power my RS2. And i cant find the connector type.
It looks like a LEMO with 9 pins.
Does anyone know the correct connector for the RS2?
best regards.
best regards.
without-connector.pdf (39.2 KB)
Do you mean this one?
If you want your own connector, I typically search for “circular connector” … This would be a 9 pin circular connector.
AliExpress or ebay or other should have a few results…
They are very specific connectors, you have to look in the Digikey LEMO catalog
Keep searching here… there are some good threads on this for the RS+, and “may” be the same, but not sure.
youre right… there is a thread to this topic.
But why is the connector type not documentet? Thats not the professional way.
Hi David,
Please check my answer from this thread:
