ReachView v2.22.7 is out for all devices
It can be seen that after the discussion EMLID team left in this new version 2.22.4 active frames for ‘Base coordinates’ and selection of ‘RTCM3 messages’ with inactive base mode. This causes the user to doubt whether it may conflict with the measuring procedure if he only works with the receiver as a rover with NTRIP. Please, dispel these doubts.
It would be very good, that when configuring in static only enable the base coordinates and in kinematic that it cancels the entry of the coordinates
‘Rover’ with NTRIP is a ‘rover’ irrelevant or ‘static’ or ‘kinematic’. ‘Base’ is what we get from NTRIP (point or VRS). :slightly_smiling_face:
I am thinking when one does not have ntrip availability and I generate my own ntrip or for when I do PPK and it is not confused between base and rover
A post was split to a new topic: Only red LED lights up on M+ after updating to v2.22.4
2 posts were merged into an existing topic: Difficulties in obtaining fixed solution during initialization time for Reach Module
Hello. I’d like you to see my post on M2 RTK solution: ReachView LLH vs RTKNAVI DEMO5 data analisys.
I think you will like it.
Hi! I’ve seen many good things about this update especially the improvement on the RTK fix. I’ve tried looking for the ReachView image for this update (v2.22.5) but can’t seem to find it. Can anybody please put up the link?
Thanks!
Hi @anzulfa39,
We’ve just updated the links to the latest image in our Firmware Reflashing guide.
thank you so much, i have succeeded ini updating my firmware to ReachView v2.22.5!
only see the firmware file: reach-rs-v2.22.5.zip, or it can be used on any Reach devices including RS2 and M2?
Hi @l3technologycambodia,
You can find the image for Reach M2 in Reach M2 Firmware Reflashing guide and image for Reach RS2 in Reach RS2 Firmware Reflashing guide.
Please note that we don’t suggest reflashing the devices without our recommendation.
Hello, guys!
We just released v2.22.6 . The list of changes is available in the first post of this thread.
Hi ! Will a dev version appear updating the RS + error of the flashing green led? or do I have to go back to stable version 2.22.6?
Hi! If you have a similar issue on v2.23.8 you can wait for a new dev release v2.23.9 that will have the same fix. If you have this issue on the dev, I suggest keeping the discussion in another thread dedicated to the v2.23.x releases.
Hi George ! Yes, in the evaluation version 2.23.8 the RS + also fails, at times the green led will blink
Hello, guys!
We just released v2.22.7. The list of changes is available in the first post of this thread.
They are going to make an evaluation version with the improvements for the RS + (flashing of the green led)
Thanks You
Thanks You
A post was split to a new topic: Legacy RTCM3 messages
