We are releasing a new very important upgrade for our Reach RS and Reach RTK. The release finally brings ReachView on all of our devices to the same version.
In order to update your device to the latest version and receive further OTA firmware updates, you need to perform a good ol’ firmware reflashing described in our docs.
The newer stable release for all devices is going to be available soon.
Good morning
I have 4 reach rtk’s tried to reflash one. The flash program never connects to the reach?
Windows 10 and reach rtk connected with usb cable
Hi, @jmcarthur!
You don’t need anymore flashall script, just run Emlid Flash Tool and choose downloaded zip archive. The process of flashing will start automatically after connecting the device.
I suspect that the problem might be connected with not providing enough power to Reach to boot. Did you previously successfully flash your device with the same cables and the same computer using flashall script?
This is on a desktop have not had to reflash these units for several years.
I just tried another unit and it did connect the flashing started and went quickly to about the middle of slider and is now sitting still for several minutes and the light on unit is sitting still solid blue pink color
I have not had any luck with the flash tool either. I cannot get past the Disconnect step. nothing is connected to the computer (Win10) yet it keeps spinning at Disconnect all Reach units and won’t go past this step.
Attached are the log files. The first few are of the !st unit that did not connect. The last few are of a different unit that did connect but half way thru the update process the unit turned off, came back on and the update never resumed.
Jimlogs.zip (26.1 KB)
Attached. The first few were from when I was attempting to update my M+, I eventually was able to connect to wifi and update that one. The rest are from the RTK. logs.zip (9.1 KB)
@gleb.gira Hi Gleb !!!Could you improve the stakeout system? Indicate two directions of measurements.
Staking is very difficult.
Example
0.50 meters north, 0.10 meters east. It would be very helpful
Thank you luis
