I am using two Reach RS+ units with Firmware 2.18.1 stable. Due to a misbehavior in RTK/LoRa configuration I was trying to reflash the firmware according to the instructions given:
Unfortunately the process ended with the message “Flashing failed”, although I followed the given instructions very carefully and set the device to firmware update mode. I tried this on two different Windows 10 systems with both my Reach RS+ units without success.
Why does the flashing fail? What else can I do to reflash the RS+ units?
I have no access to my Windows 10 system for the time being, but I remember the screen looked exactly like the one Emlid shows in the troubleshooting section:
The flashing tool recognizes my Reach RS+ units and shows “initializing…” in step 5. Then “Flashing failed” ist shown. Same behavior on both of my Reach RS+ units with firmware 2.18.1.
Yes, I have done all the steps described in the troubleshooting section to put the device in firmware update mode with the flashing LEDs. The result: „Flashing failed“.
I have the same problem on a rs2 flash fails even doing it the way that is suppossed to work if it does fail, I tried Linux also since win10 didn’t work and the same error. Not able to flash.
I tried different USB cables and even freezing the device as suggested above, with no success. The same behavior is reproducible on two different Windows 10 systems. Also the Firmware Flash Tool crashes the system with a blue screen on every second attempt. Same problem on both Windows 10 systems and both of my Reach RS+ units.
Same as my first unit, mine stopped booting and hung in flashing light mode, does yours still boot up and can be used? I tried disconnecting usb drives, usb sticks everything, linux laptop,windows laptop, linux PC windows PC, linux on virtualbox etc. Just based on quick connection etc when I ever get brave enough to use the flasher it will be on linux not windows
Unfortunately my Base is now stuck in firmware update mode with the rolling LEDs since yesterdays flashing attempts. So I can’t use my equipment anymore and would be grateful for any quick help.
@ brycethomaskennedy
How did you solve the problem with your first unit which hung in update mode?
