EBE111057
(Bryan Enfinger)
May 27, 2021, 11:04am
22
Chiz, I know it’s frustrating for you… It was for me due to my hard headiness in being an old fart of 63 years old and licensed professional Land Surveyor and not following instructions.
Follow this link to Polina’s instructions precisely, it’s about halfway down in the post:
Hi @aholsteinson ,
Thanks for your patience!
Please update your receiver to the latest 26 Firmware update to ensure that all of the latest improvements and fixes are applied. Make sure that your ReachView 3 is on the latest 5.9 version, too.
To connect the receiver to the phone’s hotspot, please, follow the steps below:
Connect to the receiver via its hotspot
Go to the Wi-Fi tab
Delete all the known networks so that the receiver doesn’t start looking for them
Insert the credentials of your …
As far as I understand, you want to update the rover. So, yes, you need to reboot the rover.
If you’d like to update the base, you need to go through these steps as well.
I’ve recorded the screencast with the workflow. Your Android device interface may differ a bit. However, there should be the same settings.
chiz
(Chiz)
May 27, 2021, 7:35pm
24
Thank you, I have tried that and it did not work. Same issue. If the instructions were precise for someone who doesn’t know their way around Emlid kit, then that would help. Step by step instructions need to assume nothing and set out everything. Give me a Leica, Trimble or Topcon and I’d have a chance
chiz
(Chiz)
May 27, 2021, 7:51pm
25
Thank you, is there meant to be sound on that?
Hi Chiz,
The screencast was recorded without sound. If some step requires additional comments, please let me know.
You can record the screencast of your actions as well. I’ll check what might go wrong.
chiz
(Chiz)
June 2, 2021, 1:53pm
27
Sorry, been a bank holiday here. Back on it now. Can I get a proper step by step guide to the process, with either verbal or text description?
Hi Chiz,
Please record a screencast with your step-by-step actions. It will help me understand which step causes difficulties and provide you with more info.
chiz
(Chiz)
June 7, 2021, 3:35pm
29
Thank you, unfortunately I haven’t been given any detailed instructions to follow, so that will be quite difficult
Chiz,
You can follow the steps Julia provided here:
I got you. At this stage, we need to connect Reach to the Internet first:
Please connect to your Reach’s hotspot and open the ReachView 3 app
Select the Wi-Fi tab in Settings in ReachView 3
Press “Connect to a hidden network”
[image]
Enter the credentials of your mobile hotspot and press the “Connect” button. At this step, Reach won’t connect to your phone’s hotspot since it’s off
[image]
Now reboot the device with the Power button
Enable Wi-Fi hotspot on your mobile device
Reach should co…
Please record the screencast or specify which exact step causes difficulties.
chiz
(Chiz)
June 8, 2021, 4:41pm
31
Thank you
Please see my earlier replies to these steps, and how they didn’t work
Chiz,
We’re also communicating with you via email. I’ve just answered you there. Let’s continue the discussion via email to avoid confusion.
