Hi @aholsteinson,
Thanks for your patience!
Please update your receiver to the latest 26 Firmware update to ensure that all of the latest improvements and fixes are applied. Make sure that your ReachView 3 is on the latest 5.9 version, too.
To connect the receiver to the phone’s hotspot, please, follow the steps below:
- Connect to the receiver via its hotspot
- Go to the Wi-Fi tab
- Delete all the known networks so that the receiver doesn’t start looking for them
- Insert the credentials of your phone’s hotspot in the Connect to a hidden network section. Please be careful while inserting them
- Press Apply. The unit should start looking for the hotspot (the network LED should start blinking blue)
- Turn off the unit
- Go to your smartphone’s settings, enable the mobile hotspot
- Make sure that the smartphone shares the hotspot on 2.4 GHz
- Turn on the unit when you’re sure the phone is transmitting its network
While turning on, RS2 should be able to detect the network and connect to it.
Please specify at which step of the integration the connection fails. The steps are described in our Getting Reach coordinates on Android via BT guide.
