Emlid Reach RS2, I experienced an issue where the mobile data connection is lost when the logs get full. I had all three logging functions on, with rolling logs. Two RS2s lost their mobile data connection when the logs got full (red bar at the maximum on Logging page). I then deleted all logs, turned logging off (all three) and rebooted. After this everything works fine. What can be causing this? Firmware v2.24.2.
This seems rather strange that the mobile data reception is affected by the memory state. You can send the Full System Report to us on support@emlid.com so that we take a closer look at it.
However, when the storage is full, the unit might indeed experience issues with the operation. That’s why we always suggest checking up space and clearing up the memory.
The rolling logs may stop when the memory is full. However, when there is no space to write the logs on the receiver, it may be difficult for it to accomplish different operations as well.
We’re always improving the way we handle the shortage of memory. So we’re currently checking out the reports that Antti shared with us.
Just wanted to tell you that we’ve found the main reason for the mobile data turns-off. It’s not related to the memory capacity. The trigger is in the modem settings. We’ll fix this in the next firmware updates.
Currently, as a workaround, it’s possible to provide the unit with the Internet via connection to the external Wi-Fi network.
Just wanted to tell you that we fixed the modem behavior in the latest Reach Firmware 26.2. Now there should be no random mobile data failure. You can find all fixes in this community post.
Please update the receiver to the 26.2 firmware version to check if the update works correctly for you. Let me know the results.
