Getting a little tired of the continued issues with our M2.
We have an M2 setup as a base with an external antenna logging for PPK. It is setup connected to wifi, and i know it has internet because i can use it for NTRIP.
However, when i want to access to get the logs i have an issue. I can see the M2 on our network, and i can see it in the Emlid Flow app. But, when i click on it to connect it fails to connect and says "Cant connect to Reach). I had the same behavior when it is in hotspot mode. The last time i had to fix it by reflashing the firmware, meaning i lost all the PPK logs that i needed. Also, i once got connected to it and restarted the device, but then got “502 Bad Gateway - nginx/1.18.0” when connecting through the web browser
Another issue is the time sync. When i reset the firmware and connected to our wifi again, the green light went solid. Then after some time, it starts to flash. Again, i know it has internet access and clear view of the sky for sattelites.
Third issue is downloading logs. It is set to record logs 24/7 and then delete the oldest logs when the storage is full. It says it is recording, but the button to stop recording is red with 0:00. When i click it to stop, it fails and gives an error message. If i refresh the app, the button will be blue with “start recording”
4.5gb of 12.1gb is used, but when i click on “recorded logs and settings” there are no logs.
Firmware is updated to the latest version
This is a device that we rely on for our ppk work flow, but it fails us so many times.
