Is it possible to connect the Reach RS over Bluetooth with a laser rangefinder to generate a offset points?
I have access to a TruPulse 360B laser rangefinder with GPS integration capabilities. We’ve used this unit in the past to collect offset points with a Trimble GPS. Can the Reach RS support this kind of offset internally, or would I need to figure out a more involved approach like @TB_RTK demonstrated in their post? Any suggestions for someone getting started with this process?
There is a second approach i`m been dying to carry out. If you stick around there should be post a about soon.
Just need to glue the rest of my lego to the plane
