I see the import DXF has been added to Reachview 3,tried several files with points only but can’t seem to get anything loaded, has anyone had any luck with this feature yet?
What sort of errors are you getting?
I just keep getting a message “Could not import the file”
Hi @Nilrac,
I suppose something can be wrong with the imported file so that ReachView 3 doesn’t load it. But I can say for sure only when I test it myself. Can you share at least one of those DXF files? You can send them to support@emlid.com if needed.
What version DXF? Probably need to stick with 2010…
