When running the emlid tool the test section says “ms5611: failed. is the barometer covered with a foam”
Which is yes because that is what the docs suggested. Question is though I changed my UAV from a quad copter to a drone. The autopilot is in a housing inside the body of the plane. Is it neccesary to still have the peace of foam
It gives me the same error with or without the foam.
But it is a bit confusing because when I calibrate the sensor using Qgroundcontrol it tells me that everything was calibrated successfully. There is a little error screen though that gives warning that says pressure differential
Did it ever work? (before you updated to stretch)
Is the casing ventilated?
Other then that, failure is always an option. Some other tech dude might have a better throuble shooting tip…?
