I’m experiencing issues with the WiFi hotspot of the RS2+. The hotspot keeps disconnecting from my Android phones (Samsung S20 and XcoverPro). When it’s connected, the Flow app sometimes manages to make a connection, but this only lasts for a few minutes. Most of the time the IP address is visible in the list of devices, but when I try to connect is says: “Can’t connect to Reach”.
I was hoping a firmware update might fix it, but it is still present in 31 beta 3. I also already checked the battery optimization settings of both phones. I don’t have these issues with my other RS2 (non-plus) receivers.
My suggestions : rollback to a stable firmware version, deactivate mobile data and bluetooth when connecting to the Reach’s hotspot, and, if you have any VPN activated on your phone, disconnect it.
Without the SIM inserted I don’t have these issues. It’s connects right away via the hotspot and stays connected. Also when I reboot Emlid Flow it finds the RS2+ right away.
How can I make this work the same way with the SIM inserted?
Disabling the data sharing option doesn’t make a difference.
I tried again with mobile data turned off (as suggested by Florian earlier). I do think that resolves the problem. That gives the same result as taking out the SIM completely. So to summarize:
When I take SIM out of the Emlid: No connection issues
When the SIM is inserted and I turn the mobile data of the Emlid off: No connection issues
When SIM is inserted, mobile data turned on, data sharing on: Connection issues.
When SIM is inserted, mobile data turned on, data sharing off: Connection issues.
I see, thank you for the summary! Can you please share a Full System report from your Reach? I’ll check it to see what we can do. The report can contain personal data, so I’d recommend sending it to support@emlid.com.
I am having the same EXACT issues with my android devices. It doesn’t matter the brand, (IE Samsung, Motorola, etc.) all of my android devices. If I cant get the mobile data to share to my tablet or other android device…what is the sense in my purchase of the RS2+ With all the “work arounds” I can achieve the same results with the RS2 for hundreds of dollars less!!! It seems as though the RS2+ is only IOS friendly…EXTRETEMLY DISSAPPOINTED with this purchase!
I also experience these problems. But not only with the RS2+, also with the RS2. Also with multiple (Android) phones and tablets.
To me it feels some instability has been introduced in the newer firmware. We have 6 antennas, of which 4 were bought recently. But with it the current issues I doubt why I selected these antennas. In my memory we didn’t have as much problems last two years.
Another issue is that some (RS2+) antennas are not discovered by the Flow app. This happens even while connected to the antenna’s hotspot. Entering the IP-address works to get access to the Reach panel.
I’ve looked into it with our devs. In some rare cases, the receiver’s hotspot connection may become unstable when there’s a SIM card inside. For now, the reasons are not fully clear, but we continue the investigation. Still, such behavior is hard to reproduce, so the research takes time. Once there are any updates, I’ll let you know.
For now, we can suggest connecting to Reach via Bluetooth as described in this thread. The Bluetooth connection is in Beta, but it may help work with a SIM card in your situation.
If it doesn’t work for you, you can also use the NTRIP over Bluetooth option or connect Reach to a mobile hotspot or a Wi-Fi network.
Please check that the mobile data is turned off on your Android device and that the Battery optimization is disabled for Emlid Flow. If it doesn’t help, please create a new thread or write us to support@emlid.com, just to keep the topics separate. We’ll check how we can help.
Any update on this one? We need the SIM inserted in the RS2+ in our use (as a reference with NTRIP via the caster). The bluetooth connection doesn’t allow to change all the settings.
There’s no news I can share now, but we are looking into the possible options. Still, finding a solution for this issue requires thorough research, so it’ll take some time. Once there are any updates, I’ll be sure to let you know.
