i have 2 unit emlid rs2 (2019) and emlid rs2 (2020) unit. both unit update to v 2.22.4 firmware.
2019 unit have a problem to connect hotspot after insert sim card and automatically disconnect but for 2020 unit don’t have any problem with hotspot and sim.
Have you tested both devices with the same SIM card?
May I ask you to update this device to the v2.23.6 dev version and check if it helps? Dev releases are mostly needed for testing purposes and aren’t intended for real-field usage. However, there is a fix that should resolve your issue.
You can subscribe to dev updates branch in ReachView Settings (gear-shaped button).
after update to v 2.23.6 dev, all my android device can use after insert sim but mobile data off every time connect to reachview. no internet receive after on mobile data.
Could you PM me the Full System report generated on the device so that I can check where the issue lies? You can do it in ReachView Settings (gear-shaped button).
I just wanted to let you know that we have released a new stable v2.24.2 firmware version for Reach receivers. In this update, we have improved the stability of mobile data. It should help to make the connection to the hotspot when the SIM is inserted more steady.
It’d be great if you could update your receiver and check how it works for you. To update, you can press the update notification in the Status Tab.
