- Firmware image and ReachView version: v2.20.7
- system report
Simple system report
app version: 2.20.7-rs2-rc0-r0
'wifi_status, interface: wlan0':
- wifi_mode: infrastructure
- ip: 131.220.233.182
is_added: true
is_connected: true
is_visible: false
mac_address: 6C:21:A2:92:72:88
security: wpa-psk
ssid: AndroidAP42
uuid: e16118f9-3b36-4d24-a373-5d8788f3e211
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: true
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1006':
enabled: true
frequency: '0.1'
'1074':
enabled: true
frequency: '1'
'1084':
enabled: true
frequency: '1'
'1094':
enabled: false
frequency: '1'
'1124':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
lora:
air rate: 2.6000000000000001
frequency: 868000
output power: 20
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: true
galileo: true
glonass: true
gps: true
qzss: true
snr mask: '35'
update rate: '5'
- Detailed problem description. How does observed behavior differ from the expected one?
We need to access an Emlid Reach RS2 unit through an ethernet switch, due some constraints, we can’t just use the USB-C connection. That’s why we thought of using a USB-RJ45 converter. A really simple diagram of the system is shown below
We can access the RS2 unit through WiFi and via the USB cable, but we can’t make it work.
After digging deep into the shown system, we realized that the Linux board on the RS2 doesn’t have the drivers to communicate with this particular dongle (USB-RJ45) or any other dongle around there.
We’ve found the drivers for this particular dongle: AX88179_DRIVER BUT we couldn’t access the root user on the linux board on the RS2. This means that we can’t cross-compile the driver and load it into the running kernel or use the open embedded package manager to install a pre-compiled driver.
Is there any way to access to root user for the RS2 linux board? We’ve tried with emlidreach, root and stuff like that but non of them worked. Also oelinux123 didn’t work
3.1) Logs
For this step we compare the kernel messages on the RS2 board and compared it against an Ubuntu 18.04 OS
Ubuntu 18.04 Logs
@laptop:$ dmesg
[263164.813481] usb 2-6.2: new SuperSpeed USB device number 6 using xhci_hcd
[263164.839477] usb 2-6.2: New USB device found, idVendor=0b95, idProduct=1790
[263164.839479] usb 2-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[263164.839480] usb 2-6.2: Product: AX88179
[263164.839481] usb 2-6.2: Manufacturer: ASIX Elec. Corp.
[263164.839482] usb 2-6.2: SerialNumber: 000050B61FB501
[263165.748581] ax88179_178a 2-6.2:1.0 eth0: register 'ax88179_178a' at usb-0000:00:14.0-6.2, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:50:b6:1f:b5:01
[263165.750331] usbcore: registered new interface driver ax88179_178a
[263165.760125] ax88179_178a 2-6.2:1.0 enx0050b61fb501: renamed from eth0
@laptop:$ lsusb
Bus 002 Device 006: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
@laptop:$ lsub -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/10p, 5000M
|__ Port 6: Dev 2, If 0, Class=Hub, Driver=hub/2p, 5000M
|__ Port 2: Dev 6, If 0, Class=Vendor Specific Class, Driver=ax88179_178a, 5000M
@laptop:$ lsusb -v
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 255 Vendor Specific Subclass
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x0b95 ASIX Electronics Corp.
idProduct 0x1790 AX88179 Gigabit Ethernet
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerial 3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 57
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 124mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 0
iInterface 4
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 11
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
@laptop:$ lsmod | grep ax
ax88179_178a 24576 0
usbnet 45056 2 cdc_ether,ax88179_178a
mii 16384 3 usbnet,r8152,ax88179_178a
# Driver is in /lib/modules/4.15.0-58-generic/kernel/drivers/net/usb/ax88179_178a.ko
RS2 Logs
reach:~$ dmesg
[ 1817.848953] usb 1-1: new high-speed USB device number 2 using ehci-platform
reach:~$ lsusb
Bus 001 Device 002: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
reach:~$ lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=, 480M
reach:~$ lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceProtocol 0
bMaxPacketSize0 64
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerial 3
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 248mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
iInterface 4
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 11
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
reach:~$ lsmod
Module Size Used by
bnep 20480 2
reachrs_plus_pmu 24576 8
hci_uart 24576 0
btbcm 16384 1 hci_uart
cp210x 24576 1
bluetooth 319488 22 hci_uart,bnep,btbcm
brcmfmac 221184 0
brcmutil 16384 1 brcmfmac
usb_f_acm 16384 1
u_serial 20480 1 usb_f_acm
usb_f_ecm 16384 1
g_cdc 16384 0
u_ether 20480 2 usb_f_ecm,g_cdc
libcomposite 40960 3 usb_f_ecm,usb_f_acm,g_cdc
configfs 28672 4 usb_f_ecm,usb_f_acm,libcomposite
reach:~$ find /lib/modules/4.17.19/kernel/
/lib/modules/4.17.19/kernel/lib
/lib/modules/4.17.19/kernel/lib/zlib_deflate
/lib/modules/4.17.19/kernel/lib/zlib_deflate/zlib_deflate.ko
/lib/modules/4.17.19/kernel/lib/crc-ccitt.ko
/lib/modules/4.17.19/kernel/net
/lib/modules/4.17.19/kernel/net/bluetooth
/lib/modules/4.17.19/kernel/net/bluetooth/bnep
/lib/modules/4.17.19/kernel/net/bluetooth/bnep/bnep.ko
/lib/modules/4.17.19/kernel/net/bluetooth/rfcomm
/lib/modules/4.17.19/kernel/net/bluetooth/rfcomm/rfcomm.ko
/lib/modules/4.17.19/kernel/net/bluetooth/bluetooth.ko
/lib/modules/4.17.19/kernel/net/bluetooth/hidp
/lib/modules/4.17.19/kernel/net/bluetooth/hidp/hidp.ko
/lib/modules/4.17.19/kernel/drivers
/lib/modules/4.17.19/kernel/drivers/reachrs-plus-pmu
/lib/modules/4.17.19/kernel/drivers/reachrs-plus-pmu/reachrs_plus_pmu.ko
/lib/modules/4.17.19/kernel/drivers/net
/lib/modules/4.17.19/kernel/drivers/net/slip
/lib/modules/4.17.19/kernel/drivers/net/slip/slhc.ko
/lib/modules/4.17.19/kernel/drivers/net/wireless
/lib/modules/4.17.19/kernel/drivers/net/wireless/broadcom
/lib/modules/4.17.19/kernel/drivers/net/wireless/broadcom/brcm80211
/lib/modules/4.17.19/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil
/lib/modules/4.17.19/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko
/lib/modules/4.17.19/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac
/lib/modules/4.17.19/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp
/lib/modules/4.17.19/kernel/drivers/net/ppp/ppp_deflate.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp/pppox.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp/ppp_mppe.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp/bsd_comp.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp/ppp_generic.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp/ppp_synctty.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp/pppoe.ko
/lib/modules/4.17.19/kernel/drivers/net/ppp/ppp_async.ko
/lib/modules/4.17.19/kernel/drivers/usb
/lib/modules/4.17.19/kernel/drivers/usb/gadget
/lib/modules/4.17.19/kernel/drivers/usb/gadget/libcomposite.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/legacy
/lib/modules/4.17.19/kernel/drivers/usb/gadget/legacy/g_multi.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/legacy/g_cdc.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/legacy/g_mass_storage.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/legacy/g_acm_ms.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/legacy/g_ffs.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/u_ether.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/u_serial.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/usb_f_acm.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/usb_f_ecm.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/usb_f_fs.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/usb_f_rndis.ko
/lib/modules/4.17.19/kernel/drivers/usb/gadget/function/usb_f_ecm_subset.ko
/lib/modules/4.17.19/kernel/drivers/usb/storage
/lib/modules/4.17.19/kernel/drivers/usb/storage/uas.ko
/lib/modules/4.17.19/kernel/drivers/usb/serial
/lib/modules/4.17.19/kernel/drivers/usb/serial/ftdi_sio.ko
/lib/modules/4.17.19/kernel/drivers/usb/serial/cp210x.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth
/lib/modules/4.17.19/kernel/drivers/bluetooth/btsdio.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/bpa10x.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/hci_uart.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/btrtl.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/ath3k.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/btintel.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/bcm203x.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/btmrvl.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/btmrvl_sdio.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/bfusb.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/btbcm.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/hci_vhci.ko
/lib/modules/4.17.19/kernel/drivers/bluetooth/btusb.ko
/lib/modules/4.17.19/kernel/fs
/lib/modules/4.17.19/kernel/fs/configfs
/lib/modules/4.17.19/kernel/fs/configfs/configfs.ko
/lib/modules/4.17.19/kernel/crypto
/lib/modules/4.17.19/kernel/crypto/echainiv.ko
- Your step by step actions.
- Turn ON RS2
- Connect USB-Ethernet converter
- ssh into the RS2 reach@192.168.2.15 (passwd: emlidreach)
- Inspect the kernel msg to see if it’s comunicating with the dongle
- Since no driver is there, when we try to reach the RS2 via the network connection we fail.
Picture of the setup and connection scheme.
Specify the exact make and model of the hardware you are integrating.
Reach RS2 L1/L2/L5 RTK GNSS RECEIVER
- Proposed solution
Install the drivers for the USB-Rj45 converter in the RS2 firmware.
We think we have 2 options, either Emlid provides us with the image that contains the driver or we gain root access and do it by ourselves. If you think there is a better solution for the scheme shown, we are more than welcome to change our approach.
We are also concerned about using other dongle, what if we change the usb-eth converter?
- Similar Topics
- Input correction base station through serial communication - #2 by egor.fedorov
- Reach User Password
- Connecting Reach RTK to Laptop using a Ethernet RJ45 Connector - #5 by bide
Thanks a lot in advance
