wizprod
(Christian Grüner)
October 26, 2019, 9:14am
#1
I cannot find a way to use precise clocks with RTKclock that works.
Each time I load a .clk (for the correct timeframe), I simply get a Q=0 solution .
I have tried with MGEX product and GPS+GLO only products as well.
MGEX: ftp://cddis.gsfc.nasa.gov/pub/gps/products/mgex/ (more info: http://mgex.igs.org/IGS_MGEX_Products.php )
GPS+GLO: ftp://cddis.nasa.gov/gnss/products (more info: https://kb.igs.org/hc/en-us/articles/115003935351 )
As I see it, this originates in that all suppliers have gone to a 5 min interval from a 15 min interval . RTKpost doesn’t seem to handle this. Problem is I can’t find 15 min products any longer. All have gone to 5 min or faster.
I don’t think you forgot to mark precise orbits
wizprod
(Christian Grüner)
October 26, 2019, 11:03am
#3
That is selected, and files pointed to.
It is only when “Precise” is chosen that the solution goes Q=0
wizprod
(Christian Grüner)
October 26, 2019, 11:05am
#5
The files are positively from/for the same date. This happens with all datasets I have tried so far (from many different dates, with their respective clocks).
I use the gnss calendar because it is more practical, sometimes I have problems of Q = 0 but it is because some configuration has been changed.
wizprod
(Christian Grüner)
October 26, 2019, 11:11am
#7
Can you work with the clks from the sites I have listed above ? Can you try ?
I try later, it’s early here in Argentina
Zinou
(Zinedine)
October 26, 2019, 1:50pm
#9
Hi Christian,
Why you don’t use RTKGET ?
I found it very useful!
wizprod
(Christian Grüner)
October 26, 2019, 1:52pm
#10
I do, but this isn’t about the download, but about using the files themselves
Can you work with the clk files?
Zinou
(Zinedine)
October 26, 2019, 1:54pm
#11
yes I worked before I did not think I had a problem!
I will try.
wizprod
(Christian Grüner)
October 26, 2019, 1:59pm
#12
Let me know how it goes! Would be both weird and nice if it works for you!
Zinou
(Zinedine)
October 26, 2019, 2:01pm
#13
Ok I remember that it worked for me and I still gained a few millimeters of accuracy.
wizprod
(Christian Grüner)
October 26, 2019, 2:04pm
#14
Please have another stab at it and let me know. Would be a huge help.
Zinou
(Zinedine)
October 26, 2019, 2:05pm
#15
No problem! I will reply ASAP.
wizprod
(Christian Grüner)
October 26, 2019, 2:50pm
#18
Let’s keep on topic here. You are most welcome to create a new thread. RTKget is very nice, and not that hard to make work (but it can be frustrating).
Zinou
(Zinedine)
October 26, 2019, 10:02pm
#19
Ok I make a screenshots …
[SC1] [SC2] [SC3] [SC4] [SC5] [SC6] [SC7] [SC8]
name
longitude
latitude
elevation
solution status
Poste
-64.952968101
-31.685835321
1179.902
Fixed
Poste 30
-64.952968107
-31.685835298
1179.899
Fixed
Poste esquina
-64.952968023
-31.685835635
1179.882
Fixed
Poste esquina
-64.953155241
-31.686315821
1179.456
Fixed
Poste esquina
-64.952770103
-31.686300714
1175.771
Fixed
Poste esquina
-64.952763313
-31.685846961
1178.211
Fixed
Poste pl
-64.954634946
-3…
I decided to use the same example of post processing seen in link above
I used GNSS Solutions to download precise ephemeris and precise clock files from IGS .
I got almost the same result as seen in a screenshot.
wizprod
(Christian Grüner)
October 26, 2019, 10:19pm
#20
can you try with the MGEX products ?
Zinou
(Zinedine)
October 26, 2019, 10:22pm
#21
I think to avoid Q = 0 you have to use both files together, you can not use the file precise clock alone!
Also seen in the RTKLIB manual
wizprod
(Christian Grüner)
October 26, 2019, 10:23pm
#22
That’s my flow. Always using both.
