Losing single solution in static mode
I am flying in the mountains and I hope to geotag my pictures using PPK. Using the ublox LEA-6H with the 3DR settings works good, using a CSG-shop ublox NEO M8N (GPS+GLONASS) with a square pcb works far better than the LEA-6H (GPS only), but using a CSG-shop ublox NEO M8N (identical configuration file as the square) with a round pcb is a complete desaster - being a beginner I have no clue why, as the ‘round’ should be identical or even better then the ‘square’ because of bigger ground plane. The reach using a 10cm ground plane would be good, but it looses the solution status single very often (positioning mode: static), none of the three other GNSS shows this behaviour. PLEASE improve this.
It would be nice to have access with u-center to the GNSS.
Hi!
Are you actually flying in static mode?
yes it is in static mode (I used this setup: PPK for dummies). Should I use other settings ?
This is not related to ReachView 2 feature requests, so moved in a new topic.
In Static mode Reach assumes that it is not moved, so when you fly it in this mode it will not be able to produce a solution (as it is moving).
In order to get help, please refere to this topic for required imformation:
