Hi, all. We own a couple of RS+. Since the last updates WiFi (hotspot) is unstable. It works and after a while, after capturing 3-4 points, the mobile loses connection, have to wait for a while to be able to reconnect and get another 3-4 points… Well, recently, we have purchased a couple of RS2 so we can get better fixes. Nevertheless, it is happening again, the same WiFi behavior… It is frustrating not to be able to use the units. We have tried with different mobiles… Is anyone experiencing such behavior? Why does the unit get locked? It is totally unusable and does not seem to be a problem of a single unit (tried four)
If connected to our office Wifi, it does seem to work right. Last update 26.1 installed…
I do… Since 26.1, Wifi Hotspot is unusable. Drops connection after a few minutes and must be restarted to regain access,… then works a few minutes and drops connection again… a nightmare,
Is it possible to specify what happens with the LED status when the Wi-Fi connection drops? Can you access the device via the browser when disconnection happens? To do that, just type 192.168.42.1 into the search bar of the Internet browser on the smartphone connected to the hotspot network.
