How did UTC time change to GPST since my Excel is in UTC?
Huh? Looks like all UTC to me? Where is this GPST???
rechview gives the time in UTC not in GPST and when using RTKLIB the time to mark the intervals is in GPST. and it differs in several seconds
some recent info is posted here:
Is this the difference of the satellite’s superior ATOMIC clock and the normal UTC clock?
I’ll just throw some links out and see who wants to jump down this rabbit hole
https://gssc.esa.int/navipedia/index.php/Transformations_between_Time_Systems
Hmm… what was the problem again?
They are both right. UTC differs from GPST with 18 seconds.
Its almost link London vs New York time, you use the one you need, right?
Thank you so much !!! subtracting 18 seconds everything works as it should be
UTC + 18 seg = GPST
GPST - 18 seg = UTC
