I’m trying to read nmea output from reach rover through usb to my computer.
I’m powering reach through usb from computer
I have 3dr radio with correction signal on the DF13 port
I must disconnect radio when I start the rover, but then it works.
but when I set: output setting: ttyUSB0 to get the nmea signal to computer
reachwiew don’t work. it"locks"
what do I do wrong?
is output through usb not ready yet?
Please flash your module with the latest firmware, we have fixed the issue with modules not starting when a radio is connected a long time ago. Here is how.
What is exactly the result that you want to achieve? I believe that what you want to do, is to have a serial port connection on your computer. This is not how USB on Reach works. USB on Reach is not just a serial to usb converter as it is in many products, it is a full-fledged USB OTG port, which means that it has numerous modes of operation. You can actually establish a network connection through it. Here you can learn how to do so.
About the lock on ReachView with an incorrect parameter, we are aware of this issue and additional validity checks are coming in the next update.
After this, how do I access files from 192.168.2.15? (my reach rtk).
This is intended for a robot to move and instantaneously receive data logs from the Reach RTK connected to it through USB. I know ssh is a possibility, but going through a wifi network might slow data transfer down and would make it harder to implement as a single piece of code that could be run to transfer data files from the Reach to the Robot directly (the robot is a Clearpath robot, running linux).
Also, how would I be able to transfer timestamped solutions to my robot?
Do you really need the log files and not the real-time data stream? You can set up NMEA output as TCP server on a certain port, for example 9000. From the host machine you will be able to access the stream on 192.168.2.15:9000.
The real time data stream would be best. Is there any other way to get the NMEA data through my USB other than using a TCP connection? Because ROS has an nmea_navsat_driver node that automatically gets NMEA data through serial USB. Let me know, thanks
I created a ROS node that reads the TCP data directly from the Reach RTK and outputs it into a ros topic. My issue now is that, after I run sudo ifconfig usb0 192.168.2.2, as described in the ethernet USB connection tutorial (https://docs.emlid.com/reach/software-development/#using-ethernet-over-usb), but it disconnects every minute and I have to keep retyping sudo ifconfig usb0 192.168.2.2 in order to re-establish connection between the computer and the Reach through TCP. Do you know of any way I might be able to fix this? Thanks
That seems like abnormal behavior. What do you connect Reach to? Do you experience lack of data on the TCP port? Can it be a power issue with Reach rebooting?
Well it does not look like I will need it. I am not using the uart out to Jackal and using the nmea_serial_drive to read that and have the 3dr radio on the usb otg. this seems to be working well, but i might need that code in the future.
