From around the 10th of October, my rs2 receiver could not take more than 1 sample per second, even though the update rate is repeatedly set at 5hz or even 10hz, through the Gnss settings panel in reachview3 app. Does anyone have any idea what might be causing that? I think the version is 6.11.
Do you mean in raw data logs? If so, have you checked the raw data log settings? You can now set the raw data refresh rate separately from GNSS settings.
No, i do measurements via ntrip provider, with a single receiver. When i post-check the measured points, i see that while the duration is e.g. 10 secs, the samples aren’t 50 (with 5hz refresh rate), but they are only 10-12.
