I tried to test it but after upgrading to 6.12 version of reachview app, whenever i pressed the (+) button to take a measurement, the app completely crashed. I tested it with 2 seperate phones (a xiaomi redmi note 9T, and a xiaomi redmi note 6 pro) with all connection methods, and got the same result. It was impossible to do my surveying work, so i downgraded to reachview 6.11, where the update rate problem maintained…I would appreciate if you checked on that crashing issue in 6.12…
After logging through previous threads in the community forum, it appears that the coordinate system GGRS87/HEPOS that i used to work with is discontinued, and replaced with Global CS. I work with ntrip correction services given by a provider, and the output coordinates are in angular format, and not in projected e.g. E=212576.899 m N=4556778.677 m U=356.878 m. You stated that whatever CS the base works with, that will be the output CS in the app, but that doesn’t work out for me, as GGRS87/HEPOS works with HTRS07
(remote) base corrections. Please notify me if you find a way to fix this, till then i guess i’ll have to work with the app’s previous version.
I see you’ve been following another thread about ReachView 3 crashes. But just in case, I’m posting here too that we’ve released the new ReachView 3 version with the fix. Please update the app and let me know if the issue persists.
One more note: GGRS87 / HEPOS wasn’t discontinued. You still can find it in ReachView 3:
