In TCP NMEA setting I am able to select 5 and 10Hz however when I apply it’s forever being in progress of change (double arrow turning) and never happens (stays at 1Hz).
I tried it thru TCP local network thru web app and reachview android app. I don’t have a serial port and I didn’t found a way to do it thru USB so I figure we can’t.
please let me know what to try.
Simple system report
app version: '26.2'
current_network:
ip: 192.168.0.120
security: wpa-psk
ssid: BRUTUS WIRELESS
enabled: true
mode: client
base_mode:
base_coordinates:
accumulation: '120'
mode: single-and-hold
output:
io_type: 'off'
settings:
cloud:
mount_point: ''
lora:
air_rate: 18.23
frequency: 902000
output_power: 20
ntripsvr:
address: ''
mount_point: ''
password: '***'
port: -1
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 9001
tcpsvr:
port: 9000
rtcm3_messages:
message_1002:
enabled: true
frequency: '1'
message_1006:
enabled: true
frequency: '0.1'
message_1010:
enabled: true
frequency: '1'
message_1097:
enabled: false
frequency: '1'
message_1107:
enabled: false
frequency: '1'
message_1117:
enabled: false
frequency: '1'
message_1127:
enabled: false
frequency: '1'
bluetooth:
enabled: false
pairing:
discoverable: true
pin: '***'
correction_input:
base_corrections:
io_type: lora
settings:
bluetooth:
send_position_to_base: false
cloud:
mount_point: ''
send_position_to_base: true
lora:
air_rate: 18.23
frequency: 902000
output_power: 20
ntripcli:
address: gps.can-net.ca
mount_point: qcvrscmrx
password: '***'
port: 2350
username: ''
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 10001
tcpsvr:
port: 10000
device:
privacy_policy_accepted: true
role: null
usage_analysis_accepted: true
logging:
logs:
base:
autostart: false
format: RTCM3
started: false
correction:
autostart: false
format: RTCM3
started: true
raw:
autostart: false
format: UBX
rinex_options:
logging_interval: 1
marker_name: null
pole_height: null
satellite_systems:
beidou: false
galileo: false
glonass: true
gps: true
qzss: false
sbas: false
started: false
solution:
autostart: false
format: XYZ
started: false
settings:
debug: false
interval: 23
overwrite: true
position_output:
output1:
io_type: serial
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: false
update_rate: 1
gst:
enabled: false
update_rate: 1
gsv:
enabled: false
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: false
update_rate: 1
zda:
enabled: false
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 115200
device: ttyGS0
format: NMEA
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
output2:
io_type: tcpsvr
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: false
update_rate: 1
gst:
enabled: false
update_rate: 1
gsv:
enabled: false
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: false
update_rate: 1
zda:
enabled: false
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: 192.168.0.111
format: NMEA
port: 22
tcpsvr:
format: ERB
port: 9001
positioning_settings:
elevation_mask_angle: 15
glonass_ar_mode: true
gnss_settings:
positioning_systems:
beidou: false
galileo: true
glonass: false
gps: true
qzss: true
sbas: true
update_rate: 14
gps_ar_mode: continuous
max_horizontal_acceleration: 7
max_vertical_acceleration: 2.1000000000000001
positioning_mode: kinematic
snr_mask: 35
